I am getting an error " VrayRT Max Render generated an exception : Aborting" when I am doing my final render.
IPR on the GPU is ok. Any advice
Best you send the scene to support@chaosgroup.com for investigation, along with the crash dump file (usually generated upon such crashes) called ‘vray.dmp’ located in your PC’s temp folder (%temp%). Please also mention your V-Ray, 3ds Max, GPU driver, OS versions and GPU model in the e-mail along with a link to this thread.
I’ve had the exact same problem…any luck?
Are your graphics cards’ drivers updated to the latest recommended version? If yes, best you send the scene to support along with the necessary files and information described above.
