Unsupported bump type - Vray Log Interactive render
someone can explain me what does it mean this warning in the file log while interactive render is running? Thanks a lot!
Hello, @valentina_esposito ​.
Can you share more information with us:
  • Which V-Ray and SketchUp versions do you use?
  • Does it happen while rendering with both CPU and GPU?
  • Is it also reproducible in newly created scene? Or is it just in older ones?
Could you please send us a test scene so we can take a look?
Kind regards,
Ivelina
Hello Ivelina,
- vray 7.00.01
- skecthup 2024
- it happens only with GPU (NVIDIA GeForce RTX 4070 Ti). Also happens that the bump doesn’t work at all, in many other occasions.
- it is also reproducible in newly created scene, i tried this morning
I share with you the map that creates problems (the are some more but the is a limit of upload in this message).
I can’t share a scene because the sistem says i’m not allowed to share skp files o vrayscene files. Tell how i could share a test scene with you, thanks!
FILE LOG.txt (22 KB)
Thank you for sharing this info, @valentina_esposito ​!
You can send us your packed project (V-Ray>Pack Project…) through our support portal (https://support.chaos.com/hc/en-us/requests/new) with the link from this forum topic in the message.​
Ok, done!!
Thank you!
We will investigate it further more and let you know what is found.
Regards,
Ivelina
