User paths on server reset on render, buckets not rendering textures.
Hi
Anybody had this problem.
Max 2012.
User paths to material library are added on server nodes.
When you render vray on workstation , the server buckets are missing the textures.
When you go back to the server and check user paths, the paths that were inserted are gone (reset)
Main workstation is running xp professional 64bit and server node is on windows 7 64 bit
Anybody have this problem and able to solve it.
Derek
This may be a Max issue.
Can you reproduce it without using V-Ray?
For a DR render, I think we are setting the project directory to be the same as the project directory of the main file, which may be throwing out the asset paths.
