Quite often i need to render large images for a customer, so i switch on my little rfarm and use the DR render.
But while it renders i’m a bit stuck waiting.
I’d like to tell Corona to render only on DR slaves, not on the host PC, so i can switch to another project / scene to go on modeling / shading / rendering locally.
What if you could put a checkbox : “Use local rendering” - ON by default, but when OFF only DR nodes are busy and your main PC fully available.
It was asked once, and one of you guys told me that it would be possible - nor easy - to implement.
Bests.
