UVW randomizer and proxies
I can’t seem to get the randomizer to work with Corona proxies. Is there a trick to this or is it a known bug?
It seems that only W rotation will work. U and V have no effect.
I’m using Max 2021 and Corona 6 hotfix 1.
I am afraid we’ll need some images or a scene example, what is your corona uvwrandomizer mode set as? Also, are you using Corona triplanar how is the node priority set?
It seems to have been an issue with the randomizer corrupting and was an issue for non-proxie geo as well. After I replaced it with a new one, using instance setting works fine.
I am glad the issue was resolved, should you encounter this again please let us know.
