Modified features:
(*) A new mode, Progressive path tracing has been added to the light cache. See the tutorial for a discussion.
Bug fixes:
(*) Crashes with dynamic geometry (VRayProxy, VRayFur, displacement etc), especially on dual hyper-threading machines.
(*) Glass with the Affect shadows option on could cause splotches with VRayLights.
(*) Skylight portals could hang with the light cache.
(*) Mapped IORs in the VRayMtl greater than 1.0 didn’t work.
(*) The VRay VFB didn’t overwrite files when the resolution of the existing file is different from the VFB resolution.
(*) Small memory leak for each rendered image (4-16Kb) removed.
(*) Meshes with 0 faces and 0 vertices could cause problems in Dynamic geometry mode.
(*) Increasing photon or light cache subdivs above 1100 did not have any visible effect.
(*) Crashes when the 3dsmax resolution is different from the VRay one and saving to file is required.
(*) Irradiance map very slow with motion blur and subdiv surfaces.
i´m at home now and not in the office…unfortunenately i can´t test the new version now. question: can we use the new light cache method (unbiased) with DR ?
…thanks a lot for the new version, it rocks…!
hey, but you forgot the color mapping ‘gamma correct’ in the roadmap…
what’s the meaning of this feature?
this is funny…you casually implement something that half the internet is raving about because someone puts a kickass gallery online with clever marketing talk about some esoteric rendering approach, which is nothing else than the lack of any optimisation (unbiased blah).
if i had this coding skills i’d spend one or two more weeks to build some template material plugins with fancy labels (dielectric isotropic phase whatever empiric) and sell it as a seperate hi end renderer called WELLMAX and get rich.
PPT is a no go with DR from my tests too. The slaves did get the scene…that’s what I was all excited about. When I got back after a break I noticed all the slaves failed…
