Good afternoon gentlemen,
regarding the solution that vlado posted a little while ago to the fellow thread
So to work around this issue please follow these steps:
1) Uninstall the 64-bit version of the V-Ray license server;
2) Install the 32-bit version of the zlib library using the command Code:
yum install zlib.i686
3) Install the 32-bit version of the V-Ray license server.
Apologies for the inconvenience; we are working to resolve the issue with the 64-bit version of the server.
The bug hunt continues... If you find a bug - report it.
First of all, V-Ray works now, even if there are many problems that occur, but it renders fine!
my report to the workaround goes like that :
1.Assumed that vlado meant the x86 vrlservice version which is included in the maya2008_x86_linux zip
2.Need to remove all installed components (vray core,wkrt,vrlservice) from and follow the procedure from the manual,
apart from installing the vrlservice x64 (didn’t work by just replacing the x64, with the x86,not sure why).
I had had zlib.i686 already installed, if you don’t, install it.
3.Once vrlservice is installed, tried to run the service and ran properly (only once) for the first time using
/usr/ChaosGroup/VRLService/linux_x86/bin/vrlservice.exe
4*.*Lastly install vray_adv normally, may need to logoff to distribute env paths properly and let vray core to load
5.After all the above done, did reboot the computer to see that everything works properly without the need of my interaction
and I could render effective immediately.
By running the deamonic (:p) service it gives the same error as in the first post
/etc/init.d/vrlsvcctl restart
Stopping V-Ray license service…done
Starting V-Ray license service…/etc/init.d/vrlsvcctl: line 21: 2403 Segmentation fault (core dumped) “$DAEMON” -daemon
failed
By running the server from /usr/ChaosGroup/VRLService/linux_x86/bin/vrlservice.exe it gives the below:
vrlservice: starting server mode; press Ctrl-C to exit.
vrlservice: Can’t open listening socket on port 30304, retrying in 5 seconds…
vrlservice: Retry [1/15]…
vrlservice: Retry [2/15]…
vrlservice: Retry [3/15]…
vrlservice: Retry [4/15]…
vrlservice: Retry [5/15]…
vrlservice: Retry [6/15]…
vrlservice: Retry [7/15]…
vrlservice: Retry [8/15]…
vrlservice: Retry [9/15]…
vrlservice: Retry [10/15]…
vrlservice: Retry [11/15]…
vrlservice: Retry [12/15]…
vrlservice: Retry [13/15]…
vrlservice: Retry [14/15]…
vrlservice: Retry [15/15]…
vrlservice: Too many retries, giving up.
Even now, the V-Ray works fine without any licencing errors
That’s all, once again I would like to thank Vlado and all the V-Ray for Maya developers for the workaround and would like to
give them back feedback by posting my solution to the problem in Fedora 13 x64.
Take care and have fun,you are doing great job !
P.S.I would like to mention that VFB History works fine and was enabled by default!!
