V-Ray 2.0: VRayBPTracer
Some images with the bidirectional path tracing in V-Ray 2.0. Obiously more work is required to make it useable (noise levels are far from optimal) but some of these images are very hard to do with the traditional V-Ray GI methods. Especially the first two - the ashtray one and the interior that is lit predominantly with reflective caustics.
Is this method work similar to PPT ?
Yep, sort of, but it traces rays from the lights as well (not just the camera), so things like caustics and multiple light bounces clear up much faster. It is mostly better for interior scenes (not much point to use it for exteriors). It is also purely an unbiased method (doesn’t use the light cache like PPT, at least not yet).
Thanks. looks very promising. :slight_smile:
Humh that VRayBPTracer is on back of my head for a long time now…
I was wondering even tho I could spend 2 days and test it myself but anyway, how do you think Vlado this BT would work with heavy caustic images? I mean car Headlights 10-20k+ renders 20 lights casting caustics and loads of reflection.
Will it look better than standard or better? &time too…
Well, it won’t be fast for certain :slight_smile: For such large resolutions, photon-mapped caustics might be more efficient. I do not know exactly though… would be good to test it in reality. If you do get to the testing, make sure you get the 2.00.02 build from our site as it has some fixes in that regard.
Will give it ago, is the 2.00.02 up already ?
The photon mapped-caustics well they are pretty…bad atm. I’m going up to 20k samples for each light and so on. Entire process is a nightmare atm to be honest. I kinda pray to u guys that at some point u’ll do some work on caustic work-flow, maybe grid alike(phopnix fd) or something like it…
Yep, it is on the site.
The photon mapped-caustics well they are pretty…bad atm. I’m going up to 20k samples for each light and so on. Entire process is a nightmare atm to be honest. I kinda pray to u guys that at some point u’ll do some work on caustic work-flow, maybe grid alike(phopnix fd) or something like it…I see. If you can get us some examples of the kind of work you need to do, it will be helpful in trying to find ways to optimize it :slight_smile:
Sure np vlado@chaosgrouop.com ?
I’ll be doing a close up of BMW rear lights soon before/after Christmas I’ll share with you the pain ! ^^
It is vlado@chaosgroup.com :slight_smile:
I’ll be doing a close up of BMW rear lights soon before/after Christmas I’ll share with you the pain ! ^^Ok then :slight_smile:
Would be great to have ability to reuse the data from bdpt pass :slight_smile:
perhaps a stupid question, but whats the BPT good for at the moment (judging the quality)?
should i take it as more or less experimental feature so far?
The first time I heard about was when ChaosGroup pimped it at some conference as being something that was good at faster caustics, so that’s the benefit. Other than that I don’t know.
Partly, yes. For some cases, esp. when rendering jewelery and stuff like that it may be able to produce images faster and with less tweaking than other methods.
ok so how do I enable this “BPTracer” ?
As i understood reflective caustics by non blurred reflective faces like mirrors should be the strength for BPT. In a short test with the demo (2.00.01) caustics render clear and fast but could not be seen in the mirror themselves. Did i something wrong or is it a technical restriction?
Humh 2 question BTtracer, can I use it without GI ? Just straight forward render+ caustics? And Controling caustits is standard right? Nothing changed…
DVP3D = its under Helper>Vray if I’m not wrong
Bechstein there is 2.00.02 on chaosgroup www or even higher, upgrade ur version I hear they work on caustics in 02ver…
one question:
does BPT work as other unbiased render engines…that means, that it works with “emitter materials” instead of light objects??
second question: is it possible to render BPT over network… with additional rendernodes…?
It can be done of course, but there is no specific requirement for it. You can use the regular V-Ray lights, including rectangle, sphere, dome, mesh, VRayIES, VRaySun lights (which are all physically accurate lights). Standard lights (omni, spot and direct) are supported provided that they are with physically accurate settings (i.e. inverse square falloff for the Omni and Spot lights). Most options of the lights (e.g. the Directionality of the rectange lights, and texture mapping) are also supported.
second question: is it possible to render BPT over network… with additional rendernodes…?At the moment, no as there was no time for the release. However it will be added in an update.
Vlado-
Looks great! Share more test images if and when you get the time, its inspiring for sure.
-Michael
