V-Ray 3.0 3dsMax Unhandled Exception BUG
An error is produced in the following steps in V-Ray3.0 for 3dsMax.
Confirming system environment:
3ds Max 2015(default setup) + V-Ray Build 3.00.07 and Latest Nightlies.
Windows 7 + core i7 + Geforce
Although checked by two or more others PCs, it is 100% of Reproduce.
1. Some create primitive.
2. Some modifire are added.
3. The key of zero to 100 frames is set to some parameters.
4. rendering start about the animation range.
5. VRay VFB shows.
6. view port is clicked during a rendering.
7. show Unhandled Exception.
Here is captured video.
https://drive.google.com/file/d/0B03VlyqmDktUaVlPa2dHMTRDT1U/edit?usp=sharing
vraylog.txt in
[2014/Aug/28|16:43:26] error: UNHANDLED EXCEPTION: Rendering region (96,96)-(144,144)
Last marker is at ./src/globillummap.cpp, line 1679: GlobalIllumMap::buildLightMap() {1}
This problem is not corrected 3.00.08.
Please check and fix.
We are unable to work around this, as it appears to be a 3ds Max issue. The only advice I can give is not to click the viewports while rendering, and to report it to Autodesk.
understanding on the problem by the side of 3ds Max.
clash report is sent to autodesk.
Thank you.
