Render crash UNHANDLED EXCEPTION
Desperately trying to render this file, at the moment just trying to render IR map every 10 frames for an animation. Have render other cameras from the same file without any trouble.
What is this error about and any ideas how I can fix it? This happens on every machine I try it on, as well as rendering locally.
2015/08/13 09:25:41 INF Adapter returned unexpected code -2 for “C:\Program Files\Autodesk\3ds Max Design 2015\maxadapter.adp.exe” “-o” “NewTask” “-l” “Info” “-j” “C:\Users\…\AppData\Local\backburner\ServerJob\cccccccc.xml.details” “-s” “15” “-n” “1” “-a” “C:\Users\spectra\AppData\Local\backburner\ServerJob\cccccccc.zip” “-d” “utf-8”
2015/08/13 09:25:41 ERR Task error: 3dsmax adapter error : Autodesk 3dsMaxDesign 17.3 reported error: [V-Ray] UNHANDLED EXCEPTION: Preparing global light manager
2015/08/13 09:25:41 ERR 3dsmax adapter error : Autodesk 3dsMaxDesign 17.3 reported error: [V-Ray] UNHANDLED EXCEPTION: Preparing global light manager
For this type of issues it will be better to send us the scene for further investigation at support@chaosgroup.com
Let us know about the version of V-Ray, that you are using and about all additional plugins in your scene if there are some.
