we have the same problem here using batch rendering with Maya 2017 Update 3 and VRay 3.5201 under Windows 7.
Rendering directly on the machine with the license server seems to work fine, but on the render nodes only the first two images are fine, then the watermarks appears. Network connection is fine.
A friend of us have the same problem on OS X, same Maya and Ray version.
Really bad as we can’t render on any render node anymore.
just used the vrservices_installer (4.3.1) that came with the 3.5201 release and installed the online license service. But the same result: Batch rendering on the license server works fine, on the render nodes the first image is fine, then the watermark appears again.
Do you have the same problem if you do a render from the Maya GUI? Or is it just in batch mode?
It would be probably best to try and debug remotely in your environment, it would be the quickest way to get to the bottom of this.
Please drop a line to support@chaosgroup.com and we’ll arrange that. I know we tried to replicate this here with no luck, but we have to figure out what’s wrong so we can fix it.
DR batch rendering within Maya works fine. Batch rendering on the render nodes doesn’t work.
Okay, thanks for your offer. I’m leaving the office for today now. Guess support will not work tomorrow, so we have to wait till next Tuesday.
Perhaps we will down grade tomorrow to the latest stable nightly (3.5201 from 2017/03/16), because we had no problems with this version. That way we can perhaps render over Eastern.
Installing the latest nightly 3.5202 didn’t helped, but after going back to 3.4006 the problem went away. So something must have changed from 3.4 to 3.5.
That might help us pinpoint the problem, thanks for the info. Would it be OK if we contacted you personally so you could provide us with more details on how to replicate the setup and try to debug this? You can email me at alexander.yolov@chaosgroup.com - it would be greatly appreciated.
Thanks to both of you for the assistance, we were able to reproduce this on our end and one of our developers is already working on it. I’ll let you know once we make progress on this.
While we tried to reproduce the problem consistently, I seem to have found one of the possible causes. The problem seems to appear only when more than one frame is rendered on the backburner render node. Therefore setting the task size to 1 for the backburner jobs will avoid the problem, but will render only one frame per task.
thanks for your feedback. This means till you fixed the problem, we can only render one frame per batch script and then the next one? We don’t use backburner or any other render manager.
