V-Ray 5, update 1 hotfix 1 now available (5.1.1)
Hey guys,
V-Ray 5, update 1 hotfix 1 (V-Ray 5.1.1) is now available for download from our website.
Build 5.1.01 Date 17 March, 2021 Change log**:**
Modified features
V-Ray GPU
  • Out-of-core improved IPR update;
  • Print device info for GPU Light cache;
V-Ray Cloud/V-Ray Standalone
  • Faster initialization of meshes with static 3D displacement;
VRayCryptoMatte
  • Add ability to work with VRaySwitchMtl;
  • Add ability for Cryptomatte to read Multi/Sub-object materials;
VRayMtl
  • Expose the VRayMtl thin-walled refraction option in the UI;
.vrscene exporter
  • Multiple standard cameras export;
V-Ray Material library browser
  • Fix issue with recursive search in the refresher script;
Bug fixes
V-Ray
  • Crash rendering scene with ForestPro 7;
  • Crash when a VRayBumpMtl is applied on an object and another VRayBumpMtl is used as an Override Mtl;
  • Error building Embree voxel tree when “Conserve memory” is enabled in certain scenes;
  • Increased memory consumption with displacement in specific cases;
  • No illumination on surrounding geometry from PhoenixFD/VRayVolumeGrid’s Fire Lights;
  • Underwater lighting is missing when the camera is under the water;
V-Ray IPR
  • Incorrect rendering during IPR when switching from None to Volumetric/SSS translucency in VRayMtl;
  • VRayPhysicalCamera Tilt & Shift is incorrect since 5.1.00;
V-Ray GPU
  • Crash with big light cache subdivs;
  • Texture on objects with normal displacement appear smudged with on-demand mip-mapping;
VRayCryptoMatte
  • Regression with node custom attributes;
VRayDisplacementMod
  • Crash with on specific geometry with Editable poly modifier;
VRayICC
  • .icc files are not loaded through the DR assets transferring;
VRayLight
  • Random modes for textures applied to VRayLight copies produce non-randomized lighting;
VRayMtl
  • Crash when setting reflection/refraction depth too high;
VRayProxy
  • Animated Alembic files do not show animation in viewport;
  • Newly created proxies with “preview from file” use the default cube for viewport selection instead of the preview geometry;
VRayUVWRandomizer
  • Crash when switching between different texture instances;
.vrscene exporter
  • Archive as ZIP is greyed out if we open another scene to export;
  • Archiving to zip or directory merges the assets instead of overriding them;
  • Missing geometry in exported scenes when there is a VRayDistanceTex and VRayDisplacementMod on EditablePoly;
  • Tile UV mapping of Bercon Tiles is not working properly;
  • “Open ME on apply” doesn’t work with drag&drop;
  • “Use Real World Scale” doesn’t work with user added libraries;
