V-Ray 7 for Houdini, Update 4.1 – now available!
Hello everyone,
V-Ray 7 for Houdini, Update 4.1 (7.40.38) is now available.
This release includes security fixes along with a large set of improvements and bug fixes for V-Ray for Houdini and V-Ray for Solaris. Updating is recommended for everyone on V-Ray 7.
Useful links:
Here’s the full changelog:
New features:
  • Background Layer: More controls for the Background layer, including size, position, and rotation
  • Bump: Bump mapping mode that isn’t affected by screen scale
  • Camera Projection: Cylinder camera texture projection
  • Chaos Account: Chaos Account window, available from a menu at any time, for signing in manually
  • Cloud Licensing: Cloud licensing enabled by default, with new licensing dialogs in the installer
  • Cosmos: Ability to import parallax textures from Chaos Cosmos
  • Cosmos: AI Material Generator that converts photos of real-world surfaces into PBR materials
  • Cosmos: Support for Chaos Cosmos multi-user mode
  • Displacement: Ability to set a pre-scaled vector texture
  • Displacement: Control for overriding the tessellation of out-of-frustum geometry when using displacement or subdivision
  • Distributed Rendering: DR2 support for V-Ray for Houdini and Solaris
  • Filmic Tonemap: Highlight Burn moved from the Exposure layer to the Linear Filmic tonemap
  • Houdini 21: Support for Houdini 21.0, including builds 21.0.512, 21.0.559, 21.0.596, 21.0.631, and 21.0.671
  • Houdini 22: Support for Houdini 22 and USD 0.26.x
  • Hydra: Render settings primitive support for USD 24.x and later
  • Installation: Installer option to opt out of AI features
  • Lens Effects: Ability for lens effects to affect the background
  • Light Select: Support for up to 256 light selects
  • LPE: Conversion of LPEs to V-Ray Light Selects where possible
  • MaterialX: Ability to override parameters such as opacity mode with primvars
  • MaterialX: Support for MaterialX 1.39 and later versions
  • MaterialX: Support for the OpenPBR Surface shader
  • MaterialX: User NodeGraph support in Solaris
  • Parallax Texture: V-Ray Parallax Texture node for creating realistic fake interiors on a single polygon
  • Performance: Builds compiled with the Intel ICX compiler and profile-guided optimization
  • Phoenix: VDB channel index support for selecting among fields with the same name
  • Prelit Workflow: Support for the prelit workflow
  • Quick Caustics: New quick caustics parameters for reflection and refraction in V-Ray Material and V-Ray Toon Material
  • Solaris: Acceleration motion blur support
  • Solaris: Cryptomatte sidecar support for USD
  • Solaris: Custom file logger support for easier husk debugging
  • Solaris: Forced primvars, similar to V-Ray for Houdini object properties
  • Solaris: Global out-of-frustum control in the render settings
  • Solaris: Motion blur from animated camera focal length
  • Solaris: Pattern matching for lights
  • Solaris: Stereo rendering support
  • Solaris: Support for the husk --threads argument to limit rendering threads
  • Solaris: V-Ray Edit Material node
  • Solaris: Velocity, width, and scale multipliers in the Render Geometry Settings LOP
  • USD: Support for native USD 25.x mesh lights (MeshLightAPI)
  • USD: Support for Nuke 17
  • USD: V-Ray for USD builds for Katana
  • USD: V-Ray for USD builds for USD 25.05 with Python 3.11 (Linux/RHEL8 and macOS) and USD 25.11 with Python 3.10
  • usdview: Access to render settings
  • usdview: Support for the domeLightCameraVisibility render setting
  • V-Ray Atmosphere: Night Sky parameters and moon positioning in the V-Ray Atmosphere HDA
  • V-Ray Material: Water caustics parameters
  • Vantage: Daemon mode for Live Link with V-Ray for Houdini
  • Vantage: Hydra viewport selection support
  • Veras: Integration of Chaos Veras in the V-Ray Frame Buffer
  • Volume Shader: Support for sampling multiple fields with the same name in one VDB file
  • Volumes: Velocity parameter in Object Properties and the Render Geometry Settings LOP for toggling motion blur on volumetric effects
  • Volumes: Vol. Step Rate parameter in the Render Geometry Settings LOP
  • Volumes: Volume Velocity Scale parameter in V-Ray Object Properties and Render Geometry Settings
Improvements:
  • Bump: Addressed bump scaling differences with old V-Ray for Houdini exports, which scaled bump quadratically in Normal Map modes
  • Cosmos: Improved rendering of Chaos Cosmos assets on render farms
  • Cosmos: Promoted the prim path parameter to the asset’s subnet in Solaris
  • Denoiser: Exposed the OIDN prefilter option in V-Ray for Houdini and Solaris
  • Exposure Layer: Improved access to the preview masks in the Exposure layer
  • IPR: Improved render element data availability when undersampling is used
  • MaterialX: Implemented the remaining non-nodegraph MaterialX nodes
  • MaterialX: Implemented value bounds for custom MaterialX textures
  • Solaris: Exported non-UV primvars as ExtMapChannels
  • Solaris: Improved IPR update speed when Make Instanceable is enabled
  • Solaris: Improved IPR updates for toggles
  • Solaris: Introduced de-duplication of identical map channels
  • Solaris: Introduced light compatibility parameters to avoid converting old scenes
  • Solaris: Optimized memory usage for crowds
  • Solaris: Reduced memory usage for nested instancing
  • Subdivision: Enabled ExtMapChannels support in the new subdivision primitives
  • TexOCIO: Improved TexOCIO performance
  • Time to First Pixel: Implemented multithreaded hair tessellation
  • Time to First Pixel: Improved multithreading for certain USD scenes
  • V-Ray Sun: Changed the time zone parameter to a float to support half-hour time zones
  • V-Ray Sun: Extended getSunTranslation and getSunRotation to work with any node
  • V-Ray Sun: Redesigned the V-Ray SunLight UI in Solaris and Houdini
  • Vantage: Implemented native support for MaterialX nodes
  • Volumes: Improved volumetric sampling with a Multiple Importance Sampling option under Render Settings > Options > Volumetrics, plus automatic step size and volume integrator controls for Environment Fog
  • VRmat: Improved memory usage when rendering .vrmat materials
Bug fixes:
  • Security: Fixes for identified vulnerabilities
  • Alembic: Alembic hair crashed when TexSampler::uvCoord sampled a map channel with inconsistent data
  • Alembic: Alembic velocity motion blur didn’t match unpacked geometry
  • Alembic: Shadow artifacts appeared on instanced Alembic objects
  • BerconDistortion: dist_map connections weren’t saved when only one input was connected
  • Bump: The Uninverted bump normals option created hard-edge artifacts on Alembics with negative scale
  • Chaos Telemetry: The Learn More link in the Chaos Telemetry dialog opened the V-Ray for Houdini documentation instead of the Chaos Telemetry page
  • Cloud: The exporter failed to create .vrscene files for animated scenes
  • Cryptomatte: CryptoObjectPath cryptomattes changed per frame with instancers
  • Cryptomatte: Object paths for nested rayserver instancers were incorrect
  • Deep Output: Some deep samples in Z-Depth merge mode had alpha below 1.0, causing compositing artifacts
  • Displacement: Displacement with rest caused a slowdown
  • Export: Not all instance data was exported to .vrmesh because of the preview particles limit
  • Gaussian Splats: Gaussian splat relighting didn’t update in IPR
  • Gaussian Splats: Regression with Gaussian splats on matte surfaces
  • GeomInstancer: ND_heighttonormal didn’t work in rayserver mode
  • GeomInstancer: Rayserver mode was missing hair shade data overrides, causing hair to render differently
  • GPU: GeomSubset materials weren’t rendered for instances in Solaris
  • GPU: MtlMulti with shader_sets_list crashed or didn’t work
  • Help: V-Ray nodes had invalid help URLs
  • Husk: A segmentation fault occurred during rendering
  • Husk: A segmentation fault occurred on a specific frame
  • Hydra: Dynamic parameter aliases weren’t supported
  • Hydra: Shaders didn’t work in Hydra 2 when final shader nodes in several material networks had the same name
  • Hydra: The Hydra delegate ignored bump_amount when wrapping bump maps
  • Installation: The Chaos Cosmos installation ran regardless of the version already installed
  • Installation (Linux only): Installation issue with the latest 7.2 builds for Houdini 21
  • Installation (Linux only): The Disable AI features checkbox wasn’t clearly visible in the installer
  • Installer: The installer didn’t prompt to close Houdini when it was open
  • Installer (Linux only): The installer didn’t delete vray_for_houdini.json from older installations, so Houdini couldn’t load V-Ray
  • IPR: Camera parameters didn’t update in IPR in Houdini 21
  • IPR: Light parameter IPR updates didn’t work in Houdini 21
  • IPR: More than one output in a V-Ray Material Builder wasn’t supported in IPR
  • Light Linking: A segmentation fault occurred with light linking
  • Light Mesh: Instancing V-Ray Light Mesh caused slow IPR updates and high memory usage
  • MaterialX: Anisotropy values close to 1 caused dark results
  • MaterialX: ND_crosshatch rendered incorrectly
  • MaterialX: Some .mtlx files rendered differently when imported through MtlVRmat than when imported directly in Houdini
  • MaterialX: StandardSurface coat_normal had no effect
  • MaterialX: The MaterialX dependency conflicted with non-default Houdini installations when loading V-Ray
  • Memory: A memory leak occurred in the local rayserver
  • MtlVRmat: A crash occurred with TexBezierCurve depending on plug-in loading order
  • Night Sky: The Night Sky blueness parameter was missing from the sunlight UI
  • Ocean Spectra: Ocean spectra crashed with the ICX compiler
  • ply2vrmesh: GeomStaticMesh face material IDs were ignored when converting to .vrmesh
  • Proxy: Object IDs and sub-object hashes were interpreted incorrectly for instanced voxels
  • RefShader: Referenced outputs might not load
  • Render Elements: Coat and Sheen elements contained the whole shader when V-Ray Material was plugged into BRDFBump
  • Rendering: NaN ray derivatives occurred in a specific scene
  • Rendering (Windows only): Rendering failed when the output path exceeded 260 characters
  • Resumable Rendering: Rendering failed or hung when resuming from a corrupt checkpoint file
  • Solaris: 16-bit .tx files caused a crash
  • Solaris: A crash occurred when a QCoreApplication was created with Python
  • Solaris: A light filter assigned in the light LOP wasn’t exported to .vrscene
  • Solaris: A material crash occurred with instances
  • Solaris: A rayserver instancer with a Node with ExtMapChannels rendered black
  • Solaris: A specific USDZ file caused a crash when V-Ray was started in the viewport
  • Solaris: Acceleration blur for instances was incorrect in a specific scene
  • Solaris: Animated shaders didn’t update in IPR
  • Solaris: Animating Transform VOP node parameters had no effect in IPR or husk
  • Solaris: AOV bind output was incorrect when the material was applied with GeomSubsets
  • Solaris: Assigning a material during V-Ray viewport IPR caused a crash
  • Solaris: bumpNormals were written incorrectly to EXR
  • Solaris: Clipper used as matte and material didn’t work as expected
  • Solaris: Color operations at a value of 1 were broken
  • Solaris: CoordSys camera projection didn’t support the NDC, raster, and screen projection modes
  • Solaris: CoordSys issue in Houdini 21
  • Solaris: Cryptomatte didn’t work with two-sided materials
  • Solaris: Cubic curves rendered differently in Houdini 21 than in Houdini 20.5
  • Solaris: Displacement scale was wrong for instances when prototypes had a non-default transform
  • Solaris: DOF was disabled when using a render region
  • Solaris: Environment fog didn’t update in IPR in Houdini 21
  • Solaris: Faces appeared faceted when using V-Ray Material SSS
  • Solaris: Film offset was incorrect with overscan
  • Solaris: Float ExtraTex AOVs rendered black
  • Solaris: Float outputs from shader nodes returned color instead of float values
  • Solaris: Gaussian splat clipping mask distance didn’t work
  • Solaris: Half-float beauty passes weren’t supported
  • Solaris: Houdini 19.5 shader translator regression
  • Solaris: Houdini 21 exported different time samples for geometry than Houdini 20.5
  • Solaris: Instances flickered
  • Solaris: Invalid depth channel values caused viewport artifacts
  • Solaris: IPR ignored the Enable Depth of Field toggle
  • Solaris: IPR updates crashed while bitmaps were still loading
  • Solaris: Issues with fog and aerial perspective interaction with volumes
  • Solaris: Issues with the Remap node value
  • Solaris: Light filters didn’t work in Houdini 21
  • Solaris: Lights affected environment fog regardless of light link settings
  • Solaris: Materials flickered
  • Solaris: Nested instancers were always unpacked for husk
  • Solaris: Normals were missing in a test scene
  • Solaris: NVIDIA AI Upscaling didn’t work for all viewport resolutions
  • Solaris: OSL didn’t work
  • Solaris: Overscan/NDC options produced a one-pixel offset in the beauty output compared to the deep output
  • Solaris: Primvar name IPR updates didn’t work
  • Solaris: Referencing Material Builders via the Reference node didn’t work
  • Solaris: Rendering to MPlay crashed
  • Solaris: Setting V-Ray parameters on a geometry light produced API schema errors
  • Solaris: Specular flickering occurred when rendering with husk
  • Solaris: SSS colors shifted when AOVs were used
  • Solaris: Switching between materials from a VRMat node with a loaded .vrscene caused a crash
  • Solaris: Switching the viewport to V-Ray reset the Qt icon search path, causing custom icons to disappear
  • Solaris: TexOCIO wasn’t written to USD when used via the FileImage node
  • Solaris: Texture parameters reset to their default color when a texture was turned off or disconnected, and misbehaved after reconnecting
  • Solaris: The $F tag wasn’t exported correctly
  • Solaris: The Collect node didn’t pick up the Switch node correctly
  • Solaris: The default signature of a parameter no longer worked
  • Solaris: The denoiser crashed under specific circumstances
  • Solaris: The denoiser wasn’t applied in the viewport when set in the Render Settings LOP
  • Solaris: The material path cryptomatte differed in Houdini 21
  • Solaris: The moon and stars weren’t rendered by default in Houdini 20.5
  • Solaris: The moon’s viewport preview didn’t update based on geographic coordinates
  • Solaris: The NVIDIA AI Upscale parameter caused the viewport render to flicker
  • Solaris: The Pattern ID node no longer found primitives or attributes
  • Solaris: The Renderable toggle in Render Geometry Settings didn’t affect GeomMayaHair
  • Solaris: The sun wasn’t exported for TexSky
  • Solaris: The V-Ray Atmosphere HDA didn’t support the Houdini 21 lights API schema
  • Solaris: The VFB wasn’t shown for husk
  • Solaris: The Visualize node didn’t work correctly with BRDFs linked into a Blend material
  • Solaris: The volume viewport picked the wrong field
  • Solaris: The VRayScene import mode was wrong when left at its default value
  • Solaris: The VRayScene LOP ignored the disable preview option
  • Solaris: The wrong Render Settings LOP was used for rendering
  • Solaris: Translucency in volumetric mode for BRDFVRayMtl was exported differently than in Houdini outside Solaris
  • Solaris: TriPlanar with rest was broken
  • Solaris: V-Ray light parameters on basic USD lights didn’t update in IPR with USD 25 and later
  • Solaris: VDBVolume didn’t work with vector fields
  • Solaris: Viewport render settings could override production settings
  • Solaris: Viewport selection wasn’t shown
  • SSS: The SSS toggle in the render settings didn’t update in IPR
  • TexMulti: Random modes had an incorrect UI and were exported incorrectly
  • Textures: EXR textures rendered black
  • Triplanar: Mirror tiling caused seams with triplanar textures in displacement or bump
  • Uninstaller (macOS only): The uninstaller didn’t work correctly with V-Ray for Houdini builds
  • USD: Dirty primitives weren’t updated in USD 25.x
  • USD: Glossy refraction issue in V-Ray Standalone
  • USD: Half-float primvars weren’t supported
  • USD: Invalid depth channel in Katana
  • USD: Light linker wasn’t supported for USD 25.x
  • USD: Nested rayserver instancers could evaluate the wrong material
  • USD: Primitive names with Unicode characters caused a crash
  • USD: Rendering results differed in V-Ray Standalone
  • USD: TexDistance might not update in IPR
  • USD: Textures were missing for some USDZ files in usdview
  • V-Ray Standalone: Materials were ignored when rendering USD scenes with USD 0.25.05
  • V-Ray Standalone: TBB didn’t respect the -numThreads parameter
  • V-Ray Sun: Enabling Geographic position > Zone produced an error
  • Variants: Enabling or disabling variants with IPR running crashed Houdini
  • VFB (Linux only): The VFB settings window fell behind the Houdini window
  • Vignette Layer: Rotating the Vignette layer beyond 45 degrees caused issues with the offset UI handles
  • Volume Shader: Using an asterisk to point to vector volumes stopped working
  • Volumes: Rendering was extremely slow when a volume had empty channels
  • Volumes: The new volume shader crashed with deep output when Deep Merge Mode was set to 3
  • VolumeVRayToon: GeomRayserverInstancer objects rendered without textures when VolumeVRayToon was in the scene
  • VRayScene: material_override didn’t work for GeomInstancer
  • Yeti: Yeti cache files didn’t render properly
Happy rendering!
Muhammed Hamed
Senior Product Manager
V-Ray for Maya & Solaris
www.chaos.com
