V-Ray 7, Update 5 is now available for download from our website for 3ds Max 2022-2027
Note:* Due to API changes, V-Ray 7, Update 5 will require updates to 3rd party plugins. Older versions will crash when used with V-Ray 7, Update 5.
Date - Nov 5, 2026
New features
V-Ray
Initial implementation of a V-Ray Volume object, Volume shader and Volume textures
Support TyFlow’s new volumetric data (Inferno)
Initial implementation of Chaos AI Assistant
Initial implementation of V-Ray SpotLight in V-Ray light
Cylinder type in V-Ray Light
Modified features
V-Ray
Hide Irradiance Map from Render setup
Enable light depth sampling for VRayLuminaire lights
VRayVelocityElement Include/Exclude Layers and IDs
Include converting Irradiance map to Brute Force suggestion in the scene open dialogue which pops up when old settings are detected
Support for Anima 7
Hide Prepass samples option from the UI
Add integration/support for animatable material index in the material switcher in 3ds Max 2026 and 2027
MultiMatteElement Include/Exclude Layers
VRayClipper Include/Exclude Layers and IDs
VRayAmbientOcclusionElement Include/Exclude Layers and IDs
VRayDirt Include/Exclude Layers and IDs
VRayDistanceTex Include/Exclude Layers and IDs
Hide Use Irradiance map parameter from VRayMtl UI and VRayToonMtl UI
Optimizations in the V-Ray Scene Converter
VRayDecal Include/Exclude Layers and IDs
Launch cosmos browser service automatically
ICX support for better CPU utilization.
V-Ray GPU
V-Ray GPU (CUDA / RTX) to print frame completion time on render end similar to CPU
Improved the rendering of 2D displacement
Improved GPU sampling, make it less error-prone
Smoother light cache updates during IPR
Equalize V-Ray GPU Gaussian splat rendering with V-Ray CPU
Add velocity data to gaussian splats
Support for VRayMatteShadowsRE in GPU
VFB
IPR with Denoise Light Cache might show noisy images
Add possibility to auto-remap file path in Image layer
VRayDenoiser/vdenoise.exe, VFB -
Optimized post effects processing during rendering
Bugfixes
V-Ray
Refractions in VRayMtl become progressively darker with low glossiness
Scatter is different in IPR after it was hidden and shown in IPR
VRayBitmap’s Start Frame parameter is broken
Add separation line above the material override
Render resolution from 3dsMax live-link not updated in Vantage
Crash resizing VFB while V-Ray IPR is running with Light cache denoise
VRscene is flipped when rendering it with motion blur
V-Ray GPU Viewport IPR + NVIDIA Denoiser + Upscale - no denoising after Light Cache
ActiveShade viewport render resolution drops when Safe Frame is on and the viewport is wider (in aspect ratio) than the render output
DR2 with V-Ray GPU Bucket rendering does not distribute reserved buckets at the end of the render to other render nodes
Tiled rendering issue using 3ds Max crop and separate image channels output
VRayMultiSubTex’s ID Generator slot info is not exported to Standalone / GPU
Exported Anima 4D characters are rendered wrong when Motion Blur is used
Incorrect render of ForestPack/RailClone with V-Ray GPU/Vantage when motion blur is enabled
Instanced VRayPhysicalCamera nodes are constantly updated in the viewport when “Automatic vertical tilt” is enabled
Crash navigating in heavy client scene with proxy deferred loading enabled
Incorrect MutiMatte element when using VRayBlend Mtl to mix materials with different Material/ Effect IDs
Displacement Amount is capped for values outside the usual 0 to 100 for maps in VRayMtl with GPU/Standalone
Difference in displacement shift between V-Ray Production in 3ds Max and GPU/Standalone
V-Ray Bitmap “View Image” window appears off-screen in multi-monitor setups with ultrawide display
VRayVolumeGrid with VDB file renders wrong on Chaos Cloud/Standalone Linux when ‘Flip Up Axis’ is used
VRayStereoscopic helper’s “Adjust Resolution” is not considered when submitting a job through 3ds Max
3ds Max freezes after GPU IPR render of TyFlow scenes where Motion blur duration is above 1
Highlights to most modified parameters in V-Ray GPU render setup are still applied with the highlights option disabled
Opacity mapped objects appear outside render mask when a thick VRayEnvironmentFog is present
Chaos Cosmos importer - importing assets with variants show error and possibly variants do not work properly
VRayMtl bump map multiplier is not exported to Vrscene for VRayNormalMap when it only sets additional bump
Planar from Object XYZ mapping is motion blurred additionally
Crash with Standalone on closing VFB when VRayCryptomatte RE is used (regression)
Incorrect written VFB ‘primitives’ stamp data saved in animated sequence images
Artifacts with Adaptive lights and Environment fog
DR2 | The “Follow Mouse” option does not work
Wrong visibility overrides for decals in VRayPhysicalCamera on IPR
VRayLight surface is not updated in IPR when the light’s type is set to Sphere
V-Ray Physical Camera: crash when using focus picker during creation mode
VRayPhysicalCamera with object focusing flickering in the viewport when using Orbit
VRaySphereFade in a scene with dome light rendered incorrectly in Standalone
V-Ray GPU
Instanced VRayEnmeshMod randomly shows the base/source mesh after a change in V-Ray GPU IPR
Samples limit is not respected
Crash when rendering with V-Ray GPU using DR2, Bucket mode, and large image resolutions (4K)
Adaptive lights renders more than necessary with compact sampling enabled
Hide CUDA tab if there are only AMD GPU-s in the system
Regression: CUDA error with a VRayTriplanar projected Normal map
Crash with CUDA error on render with specific scene file and hiding unhiding objects
The metalness’s reflection of a matte object is always visible in the Alpha (even if Affect Alpha is disabled)
GPU memory leak approx. 215-250 MB when rendering with out-of-process from 3ds max
Crash with caustics and interactive light cache
Discrepancy between CPU and GPU with Cylindrical Point Camera
Support for motion blur for photon tracing for all lights
Freeze with 3ds Max 2026 and 2027 UI when selecting gpu device and Slate material editor is opened
Crash with VRayExtraTex RE with VRayEdgesTex with VRayPlane
Artifacts on rendering a client’s scene on HIP and HIPRT
RGB primaries in VRayBitmap is ignored when the same file is used
Endless Light cache calculation with specific scene
The automatic resolution adjustment from Stereoscopic rendering does not work in Standalone/Cloud
BRDFCarpaint2 coat bump not evaluated on GPU
Render elements are not rendered correctly for shaders with refraction affecting All Channels
Bad VRayStochasticFlakesMtl results when rendered through transparent objects
VFB Stats Tab displays incorrect available and used memory information
VRayMtl’s Bump multiplier does not work when the map type is ‘Normal map in tangent space’
Different results when rendering a combination of CompTex and DistanceTex with V-Ray and V-Ray GPU
The distance texture slot of VRayDistanceTex is not working correctly using V-Ray GPU
VFB
Crash when quickly loading images from VFB history
Crash when attempting to delete the Histogram Layer via MaxScript and afterwards switching between images in the History
Slow bucket refresh when using Curves or Exposure corrections
TIFF (8/16 bit) and 16-bit PNG saved with color corrections look washed out when loaded back
Wrong Composite result in history save and enhancement EXR
VFB Crash with missing LUT asset file
A denoiser layer with an opacity less than 1 is not automatically applied if a Sharpen/Blur layer is also present
VFB’s Image Layer Color Picker value precision issues
VFB does not keep the last stop render option used
Enhancer upload image preview is broken if we have denoiser in the VFB layers
The opacity slider of the Lens Effects layer is not considered in the effectsResult/Glare channels (only in the RGB)
Crash upon loading recent files into the VFB Image layer
Some options for saving History images to files do not work as expected
Artifacts appear in the background while rendering with Image layer added to Backgrounds folder
Some color transformation options in the Background layer in the VFB are not greyed out when the mode is set to Color
Files containing Alpha Channel cause issues when loaded as a Background or a Foreground in the V-Ray Frame Buffer
Vrimg file is not deleted after a completing a render with Resumable Rendering and Bucket Sampler
Extra attributes about raycast and primitive count stats are missing from Raw images (EXR and VRImg)
- Upscaled image briefly displayed while calculating GI with using VRayDenoiser with Denoise Light cache option enabled
Security
- Fixed security issues
