V-ray crashes SU 2020
I have installed the latest patch and I am still not able to rendering the most simple scene.
Hi @chris_letourneau
Can you provide more details regarding the crashes:
  • What was the last V-Ray version you were using before installing the latest one?
  • Is the problem occurring with specific project/s or does the same happen if you open a brand new scene? If it does occur with a specific project, please do forward it to support@chaosgroup.com for further investigation. Make sure to mention this thread in the email
  • Are you using any additional 3rd party plugins? If so, please disable them and try running SketchUp with only V-Ray enabled to check if this is happening due to some discrepancies between plugins
  • Would it be possible to provide sample crash dump and log files - should be located in Users\***\AppData\Local\Temp and Users\***\AppData\Roaming\Chaos Group\V-Ray for SketchUp
Hi, I am also facing the same issue. I recently installed SketchUp 2021 and V-Ray 5. When I run the render, it will only display 50% of the model in the frame buffer window and then crashes 10-20 seconds later. OS Windows 7.
@mictd001 Please keep in mind that V-Ray 5 for SketchUp is not supported on Windows 7.
To see the full list for system requirements, please visit https://docs.chaosgroup.com/display/…m+Requirements
Thanks Nikoleta for the response. Is it possible to re-download the previous version of V-Ray?
Yes, if you go to our download page https://download.chaosgroup.com/?lic…201&product=47 and click on Show all versions, you will be able to choose previous ones.
