V ray for 3ds max macroScript pops up after pressing Wireframe
A macroScript pops up after pressing Wireframe
Which version of V-Ray do you use. If you are using V-Ray 3.x could you try to delete the following files VRay-VRayGPUViewportIPR.mcr and VRay-VRayViewportIPR.mcr located here and try again:
C:\Users\<YourUsername>\AppData\Local\Autode sk\3dsMax\2019 - 64bit\ENU\usermacros
Hi Martin, thanks for your response, but it is not working unfortunately, same error message pops up. Below is the version of 3ds max and V-ray
3d max version: 2019
Vray version: V-Ray 3.60.05 for 3ds Max 2019 ADV
Windows version: win10 64bit
I seem to get the same message too when I install V-Ray 3.7 after I’ve had V-Ray Next installed. Will look into it.
Hi, we have fixed this in the last update of V-Ray Next, that is currently on the site, the code in the scripts should look like this for example:
on isEnabled do (
if (vrayViewportIPRControl!=undefined) then
vrayViewportIPRControl 0 1
else
false
The problem is that 3ds Max caches the macroscripts and they are loaded even if V-Ray is uninstalled, you should delete all the .mcr files that start with "VRay - " in the “C:\Users\<YourUsername>\AppData\Local\Autode sk\3dsMax\2019 - 64bit\ENU\usermacros” folder. The needed files would be recreated anyway on the next run.
Alexander
