V-Ray Next for SketchUp, update 2.2 is now available!
It can be download here:
download.chaosgroup.com
After installation, you will find more detailed info about the changes in the ‘VRayForSketchUpReleaseNotes’ and the ‘changelog’ files:
.\Chaos Group\V-Ray\V-Ray for SketchUp\extension\VRayForSketchUpReleaseNotes.htm
.\Chaos Group\V-Ray\V-Ray for SketchUp\extension\changelog.txt
Konstantin
Improvements & Bug Fixes
  • Chaos Group License Server is updated to version 5.5.0
  • V-Ray Swarm is updated to version 1.4.4
  • The Chaos Group License Server web page now automatically opens after successful V-Ray installation
  • The Material Random Color render element now correctly generates unique colors for materials passed through a Two Sided shader or ones using the Translucency attribute
  • The way materials are stored in a Proxy Mesh Component is updated. This resolves various issues with 3rd party plugins utilizing V-Ray Proxies
  • An issue with the Sun light caustic photon emission is resolved. The emission cone is no longer cut in half in some situations
  • Adding a Bitmap diffuse texture to a material (or loading one with such texture assigned) no longer activates the SketchUp’s ‘Colorize’ material option
  • Coat layers (Diffuse or Reflection) added to a material that has no other base layer no longer display the full set of VRay Mtl parameters
  • CUDA hybrid rendering in bucket mode no longer leads to exception in V-Ray Core when NVLink is used
