After upgrading to V-Ray Next for Maya 2016 I am getting on error printed on every new scene upon clicking the Render Settings window.
// Error: file: C:/Program Files/Autodesk/Maya2016/scripts/others/createMayaSoftwareCommonGlobalsTab.mel line 50: setParent: Object 'commonTabColumn' not found. //
This happens once and the ‘Common’ tab in Render Settings is blank. If you then navigate through the Vray, GI, Overrides tabs etc, and back to the Common tab, it displays as it should and all seems ok.
Is there a reason why this is happening and a way to fix?
Can you try re-installing V-Ray, but after uninstalling it, make sure there are no errors in the uninstaller and that no vray files are left in program files (on windows) or wherever the install location is. This was fixed long ago and should not be a problem even with 3.60 or Next.
