Did you install V-Ray locally on the machine or you are loading from a network location? The V-Ray installation modifies some of the original Maya scripts (createMayaSoftwareCommonGlobalsTab.mel and unifiedRenderGlobalsWindow.mel) in order to fix this specific issue. However if you are using the original scripts, or custom versions that don’t have the V-Ray fixes (there are several ones floating in the net out there related to mental ray, I believe), then you will get this issue, in which case you will have to manually add the modifications to those scripts.
There is nothing more that we can do about this on our part.
This problem happens also if you reinstall Maya and try to use it with an old installation of V-Ray for Maya.
A reinstallation of V-Ray for Maya will fix it.
Yea I have a bit of custom stuff here + a lot WIP progress so I guess this is broken over here. I’m pretty sure its Mental Ray UI 9.2.2 or so that causes it… How can I manually fix it ?
3) In a new Explorer window search for each files in your Maya install sans the ‘mod_’ part. Hint - They are mel files so adjust the file extension too.
4) The way the modification works is that for each ‘mod_’ text file there is the following:
First number.
Existing Maya Code.
Second number.
Vray Code to Add.
5) Search each file for the ‘Exising Maya Code’. Hint - the first number is the number of lines of code to look for.
6) Paste in the ‘Vray Code to Add’ after these lines. Hint - the second number is the number of lines to paste.
7) Save and be happy (if you did it right).
