Hello, I need the help of our community. I have two questions:
1. Is there any possibility of creating a V-Ray Proxy model where I am able to determine the low-poly textured object to replace the high-poly in the viewport and render only the high-poly object to be rendered?
2. Is there any way to create a V-Ray Proxy model with a more similar shape with the original template and with applied textures?
We have a couple of proxy export options that automatically create a simplified version of the object for the viewport - f.e. setting the “Preview type” parameter in the “V-Ray mesh export” window to “Refined Clustering (quality)”. You can also specify a custom object to use for the viewport preview if you enable the “Specify preview mesh” checkbox and pick a mesh from the scene.
