With V-Ray proxies, if V-Ray can not find the proxy mesh in its specified map path it will look for it in your bitmap path mappings automatically.
So if you need to network render and the proxies are not in a folder accessable by the slaves just add the path to your map paths and V-Ray will find them without you having to manually edit the path for each object individually.
-dave
