Render a region with VFB
Open V-Ray quick settings UI
Re render scene
Render Region will draw but instead of rendering in the render region, V-Ray renders the whole image. The only fix is to restart Maya.
Kind Regards,
[2016/Aug/19|09:20:14] V-Ray: V-Ray for Maya version 3.45.01, revision 26877 from Jul 30 2016, 04:35:55
[2016/Aug/19|09:20:14] V-Ray: V-Ray core version is 3.25.01
I can’t reproduce this even by using the same V-Ray build and the steps provided.
Maybe if you attach one Maya file (can be empty scene) this will help.
You’re right - I think it is just a bug with a very specific scene. Once I tried to strip down the scene to send in (removed the maya ascii references) the render region worked again. It’s odd.
I can send you both a screencast of the issue. If you are still interested in the bug, I could package together the scene (It’s quite a large scene)!
Then it would be definitely helpful to see that scene. We can provide FTP access to upload all files required to reproduce the issue, just drop us an email to support@chaosgroup.com
Thank you.
