Hi
I cant get the V-Ray RT 3.20.01 to work.
I am using 3ds max 2016
When I render using the Active Shade. Engine CUDA
It stops at waiting for data… I get a black screen.
My GPU is a Nvidia k5000 it is running at %12 ?
I am using the latest drivers 353.06
My scene is…
Vray Plane with a Tea Pot
Vray Light Plane and Physical Camera.
Am I doing something wrong?
Yeah, there were issues with this driver and many of the V-Ray versions as we have noted here http://docs.chaosgroup.com/display/VRAY3/GPU+Rendering##
In V-Ray 3.20.02 we have found a workaround for that driver bug, so if possible use that.
And please check that V-Ray is not running as a service.
nomads
June 9, 2015, 10:54am
3
Thanks Blagovest
It’s now working. V-Ray 3.20.02 fixed the issue.
Since installing vray_adv_32002_max2016_x64
I noticed my GPU is running at %8 all the time? (before I have even tried rendering)
When I render with Adv node the GPU stops.
vlado
June 9, 2015, 2:39pm
5
I don’t think it’s V-Ray; we don’t do anything with the GPU when not rendering. It might be due to the drivers though.
I also noticed when Vray Adv finishes a render the GPU starts running again at %8
If I press render Adv and the confirm overwriting dialogue box appears the GPU stops. If I close max down GPU stops.
Its a bit odd
