I’m having a few issues getting v-ray rt working using the gpu opencl. Every time I try to render with either the production or activeshade mode I get to “waiting for image data” in the frame buffer and then “V-ray Standalone has stopped working” pops up. Works fine with the cpu just not the gpu.
Which Vray version you are using?
Does the crash occurs on every scene - have you tried to render a very simple scene with a few basic primitives?
What about OpenCL mode? Does it work or not?
Have you tried with older drivers like 337.88 ?
I have discovered it happens when I use heavy HDR maps with dome light (around 400MB+)
When I use smaller HDRs everything is fine.
I will try 337.87 and report back.
I red comperations online that most of them claimed Nvidia are crippled in OpenCL, so I don’t want to use that on regular basis (yes, that same crash happens no matter OpenCL or CUDA)
