An old problem is back - each V-Ray modul gets an own task bar entry. I hope it can be fixed again.
(Win10(1909(18363.1316))|Rhino7|VfR5)
No, I need the labels and i don’t want to group all open Rhino tasks. It was working in the past after a fix was applied. Now the issue is back. It could be nice to get the fix again. ![]()
Hum, I’ll talk to the devs and get back to you.
Hi Micha,
Could you please check if environment variable VRAY_WINDOW_NO_COMBINE is defined.
@nikolay.bakalov The variable wasn’t defined. I did it and set it 1. Restart Windows. It doesn’t work. Set it 0 and restart - it doesn’t work.
You must not have this variable defined at all, not 0, not 1, nothing at all
When this started to happen ?
Your post is from March 3rd, did it work before ? with Update 1 ?
I’m trying to figure out if this is a result of an external reason (windows update, rhino update), or it was from our code
I can’t reproduce it on 2 machines, can someone else try ?
Sorry, I don’t know when it started. It can be since some time.
