V-Ray User Integer to UV Randomizer node
Just trying to use a V-Ray User Integer node to read an integer attribute as a seed in a UV_randomizer, but it doesn’t work.
I tried all the different class of attribute but nothing work.
Is this the correct way to proceed?
Works fine for me:
Doesn’t work on my side.. anything i am doing wrong ?
You have the same seed value for all primitives, try this code with the wrangler:
i@seed=int(rand(@ptnum)*@numprim);
