I’m using animated VDB files with Volume Grids and was wondering if it’s possible to hold a frame of the VDB?
Any help would be appreciated, N
Just as a thought, if they are animated that means they read from a cache, no?
So you could just duplicate the cached file at a given point, to create the freeze.
Maybe it’s not as simple as that but it seems so…
Yes, that would work. It would be good to know if there was functionality to hold the frames aswell.
Thanks.
It’s not a direct way, but setting the Play Speed to 0 and controlling the start frame through the Cache Origin seems to work.
That works perfectly, thank you!!
