Vantage 3.4 - w/ Live Link - Scene Settings Not Saving
Vantage Version 3.4.0
Sketchup 2026 Live Link
Vray 7.40.01
I am having an issue with the Environment Sub States.
Having created a sub state, then enabled and changed the Sun and Moon Settings to Geolocation, and then set a custom time of day, coordinates etc. I updated the sub state then saved the Vantage scene.
However I cannot find a way to save this and reuse later with another live link.
When I restart the live link and go to ‘open scene as config only’ the names of the sub states I created appear correctly, but none of the settings I created load correctly. They remain the default.
Is this a problem with live link?.
The settings do appear if i create them in a standalone version of Vantage, save then load into another standalone version.
I also have the sun in the sketchup file switched off in asset editor in case that created an issue. - it did not resolve the issue.
I tested this in Vantage 3.3.4 as well and it had the exact same problem.
I hope this can be resolved as we have lost a lot of time setting up custom environment scenes only to lose it all.
Thanks,
N
Do you have any warnings in the log when opening the config with the environment sub states ? The settings you mentioned are linked to the Sun light, so if its name changes they can’t be loaded and there will be warnings logged.
This is everything that is logged when i start the live link and then load the scene as config only. I dont know what im looking for here.
20:50:35.909 [inf] === 10/02/2026 ===
20:50:35.908 [inf] Chaos Vantage v3.4.0 (build 5203107, hash d9aa32ea)
20:50:35.908 [inf] Build date: Sep.23.2026
20:50:36.074 [inf] System memory: 31.95 GB
20:50:36.074 [inf] Windows version is 10.0.26200.
20:50:36.074 [inf] Hardware accelerated scheduling: ON
20:50:36.074 [inf] TDR level: 0
20:50:36.074 [inf] TDR delay: 2
20:50:36.100 [inf] Device #0: NVIDIA GeForce RTX 4080 SUPER, 16047 MB (DevId=0x2702, SubSysId=0x89781043, LUID=67568)
20:50:36.100 [inf] Output device: \\.\DISPLAY1, HDR=0, BitsPerColor=8, ColorSpace=0, RedPrimary=(0.681, 0.312), GreenPrimary=(0.268, 0.663), BluePrimary=(0.150, 0.049), WhitePoint=(0.312, 0.329), MinLuminance=0.355, MaxLuminance=343.7, MaxFullFrameLuminance=343.7
20:50:36.289 [inf] Device #1: Microsoft Basic Render Driver, 0 MB (DevId=0x8C, SubSysId=0x0, LUID=74759)
20:50:36.289 [inf] Using device #0 [1 node ].
20:50:36.289 [inf] NVIDIA driver version 616.92 detected.
20:50:36.328 [inf] Base renderer initialized in 418.8 ms
20:50:36.360 [inf] AMD Ryzen 9 5950X 16-Core Processor, 32 threads
20:50:36.361 [inf] Created ThreadManager for 32 threads
20:50:36.405 [inf] Loading 1218 V-Ray plugins took 43 ms.
20:50:36.552 [inf] Loading USD support took 116 ms.
20:50:36.564 [inf] Detected 80 SMs for device ‘NVIDIA GeForce RTX 4080 SUPER’.
20:50:36.603 [inf] SER is supported for device ‘NVIDIA GeForce RTX 4080 SUPER’.
20:50:40.659 [dev] createRaytracingPipelineState (device 0) took 4054 milliseconds !
20:50:40.675 [inf] Creating all shader pipeline states took 4072 ms.
20:50:40.769 [dev] new TextureManager time : 0.09 seconds
20:50:40.839 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 284 MBs (0 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 0 MBs for local results, 2 MBs for look-up tables).
20:50:40.911 [inf] No VR headset available.
20:50:41.183 [dev] NVIDIA DLSS-RR Minimum driver version was reported as : 537.2
20:50:41.237 [inf] Initializing denoiser and post-processing took 395 ms.
20:50:41.237 [dev] NVIDIA DLSS-FG Minimum driver version was reported as : 520.0
20:50:41.237 [dev] NVIDIA DLSS-MFG is not supported on this device
20:50:41.310 [dev] new Scene time : 0.01 seconds
20:50:41.331 [dev] Creating output resources took 21 ms.
20:50:41.332 [inf] Scene scale set. One scene unit equals 0.010000 meters.
20:50:41.333 [inf] Scene cleared in 0.00s.
20:50:41.341 [dev] Copying geometry data to GPU took 7 ms.
20:50:41.341 [dev] Building and compacting BLAS buffers…
20:50:41.348 [dev] Build schedule : 2 ms (buffers : 2 ms, command (CPU) : 0 ms); Build command (GPU) : 3 ms.
20:50:41.348 [dev] Compacting BLAS buffers took 1 ms and saved 0.00 Kbytes on the GPU ( 0.00 % ), required additional 192.00 Kbytes during compaction.
20:50:41.348 [dev] BLAS build and compact took 7 ms for 3 BLASes.
20:50:41.391 [dev] Using 0 lights.
20:50:41.393 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 287 MBs (4 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 0 MBs for local results, 2 MBs for look-up tables).
20:50:41.393 [dev] Updating GPU lights took 44 milliseconds to execute.
20:50:41.393 [dev] TLAS build took 0 ms !
20:50:41.393 [dev] Memory for all 0 shading graphs : 0.00 KBytes.
20:50:41.394 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 287 MBs (4 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 0 MBs for local results, 2 MBs for look-up tables).
20:50:41.394 [dev] Shading graph local result slots per thread changed to 1.
20:50:41.394 [inf] Loaded 2 8-bit textures from disk using 0.04 GBs of additional CPU memory.
20:50:41.394 [inf] Texture loading wait : 0.00s. Load : 0.15s. Build mipmaps : 0.00s (0.00s idle). CPU memory used for textures : 0.04 GBs.
20:50:41.394 [dev] Geometry mem | GPU dedicated : 20.23 K ( 576.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 20.23 K ( 576.00 K alloced) | CPU : 42.42 K |
20:50:41.394 [dev] Instance mem | GPU dedicated : 0.00 K ( 0.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 0.00 K ( 0.00 K alloced) | CPU : 12.68 K |
20:50:41.394 [dev] BLAS mem | GPU dedicated : 23.00 K ( 192.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 23.00 K ( 192.00 K alloced) |
20:50:41.394 [dev] TLAS mem | GPU dedicated : 0.00 K ( 0.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 0.00 K ( 0.00 K alloced) |
20:50:41.394 [dev] Total geom mem | GPU dedicated : 43.23 K ( 768.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 43.23 K ( 768.00 K alloced) | CPU : 55.10 K |
20:50:41.394 [inf] Process Dedicated | Budget : 14.92 G, Usage : 1.22 G, Available for reservation : 7.59 G, Current reservation : 0.00 K
20:50:41.394 [inf] Process Shared | Budget : 15.22 G, Usage : 264.52 M, Available for reservation : 7.74 G, Current reservation : 0.00 K
20:50:41.394 [dev] --------------------------------------------------------------------------------------------------------
20:50:41.394 [dev] ------------------------ Memory Manager State
20:50:41.394 [dev] 0.00 Kbytes in 0 free heaps.
20:50:41.395 [dev] Tier ’ Forever’ | heaps : 1 | free ranges : 1 | total : 64.00 Mbytes | free : 44.06 Mbytes | largest range : 44.06 Mbytes
20:50:41.395 [dev] Tier ’ Frame’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:41.395 [dev] Tier ’ Temp0’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:41.395 [dev] Tier ’ Temp1’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:41.395 [dev] Total managed memory : 64.00 Mbytes !
20:50:41.395 [dev] --------------------------------------------------------------------------------------------------------
20:50:41.395 [dev] Light cache factor set to 2.08
20:50:41.419 [inf] Lavina core initialized in 0.58 seconds
20:50:41.741 [inf] Window initialized in 5413.0 ms
20:50:41.746 [inf] Starting local HTTP command server on port 20702.
20:50:41.771 [inf] Cosmos HTTP service is configured at 127.0.0.1:30305
20:50:41.771 [inf] Cosmos HTTPS service is configured at 127.0.0.1:30306
20:50:41.773 [inf] Connected to local Cosmos service:
20:50:41.773 [inf] state: running
20:50:41.773 [inf] services: online
20:50:41.773 [inf] version: 2026.09.23-719497 build 719497 (latest is 2026.09.23-719497)
20:50:41.773 [inf] frontend: https://cosmos.chaos.com
20:50:41.773 [inf] backend: cosmos.chaos.com:443
20:50:41.773 [inf] workdir: D:\Chaos Cosmos\Packages
20:50:41.773 [inf] logdir: C:\Program Files\Common Files\Chaos\Cosmos\cb.log
20:50:43.251 [inf] Started live link server on port 20701
20:50:43.282 [inf] Started live link v2 server on port 20703
20:50:43.326 [Wrn] C:\Users\admin\builds\48QVksJTk\0\lavina\lavina\src\vrdx_scene_live_link2.cpp:89 [-824] Refusing service to 127.0.0.1, requested incorrect service inquiry
20:50:43.375 [dev] Light cache factor set to 4.17
20:50:43.585 [inf] Camera tracking stopped.
20:50:43.623 [inf] Camera tracking plugins loaded.
20:50:43.623 [inf] Total initialization time: 7.72 seconds
20:50:44.157 [inf] Scene scale set. One scene unit equals 0.010000 meters.
20:50:44.157 [inf] Scene cleared in 0.00s.
20:50:44.176 [dev] Copying geometry data to GPU took 5 ms.
20:50:44.176 [dev] Building and compacting BLAS buffers…
20:50:44.180 [dev] Build schedule : 2 ms (buffers : 2 ms, command (CPU) : 0 ms); Build command (GPU) : 0 ms.
20:50:44.180 [dev] Compacting BLAS buffers took 1 ms and saved 0.00 Kbytes on the GPU ( 0.00 % ), required additional 192.00 Kbytes during compaction.
20:50:44.180 [dev] BLAS build and compact took 4 ms for 3 BLASes.
20:50:44.215 [dev] Using 0 lights.
20:50:44.215 [dev] Updating GPU lights took 28 milliseconds to execute.
20:50:44.217 [dev] TLAS build took 0 ms !
20:50:44.217 [dev] Memory for all 0 shading graphs : 0.00 KBytes.
20:50:44.217 [inf] Loaded 4 8-bit textures from disk using 0.01 GBs of additional CPU memory.
20:50:44.217 [inf] Texture loading wait : 0.00s. Load : 0.03s. Build mipmaps : 0.00s (0.00s idle). CPU memory used for textures : 0.06 GBs.
20:50:44.217 [dev] Geometry mem | GPU dedicated : 20.23 K ( 576.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 20.23 K ( 576.00 K alloced) | CPU : 42.42 K |
20:50:44.217 [dev] Instance mem | GPU dedicated : 0.00 K ( 0.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 0.00 K ( 0.00 K alloced) | CPU : 12.68 K |
20:50:44.217 [dev] BLAS mem | GPU dedicated : 23.00 K ( 192.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 23.00 K ( 192.00 K alloced) |
20:50:44.217 [dev] TLAS mem | GPU dedicated : 0.00 K ( 0.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 0.00 K ( 0.00 K alloced) |
20:50:44.217 [dev] Total geom mem | GPU dedicated : 43.23 K ( 768.00 K alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 43.23 K ( 768.00 K alloced) | CPU : 55.10 K |
20:50:44.217 [inf] Process Dedicated | Budget : 14.92 G, Usage : 1.13 G, Available for reservation : 7.59 G, Current reservation : 0.00 K
20:50:44.217 [inf] Process Shared | Budget : 15.22 G, Usage : 352.96 M, Available for reservation : 7.74 G, Current reservation : 0.00 K
20:50:44.217 [dev] --------------------------------------------------------------------------------------------------------
20:50:44.217 [dev] ------------------------ Memory Manager State
20:50:44.217 [dev] 0.00 Kbytes in 0 free heaps.
20:50:44.217 [dev] Tier ’ Forever’ | heaps : 1 | free ranges : 3 | total : 64.00 Mbytes | free : 42.94 Mbytes | largest range : 41.06 Mbytes
20:50:44.217 [dev] Tier ’ Frame’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:44.217 [dev] Tier ’ Temp0’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:44.217 [dev] Tier ’ Temp1’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:50:44.217 [dev] Total managed memory : 64.00 Mbytes !
20:50:44.217 [dev] Light cache factor set to 4.17
20:50:44.325 [dev] Creating lights’ UI took 0.08 seconds.
20:50:44.328 [inf] Cannot create a connection to the 3DMouse.: not connected
20:50:44.343 [inf] License obtained successfully (1).
20:50:44.425 [dev] Light cache factor set to 4.17
20:50:44.466 [dev] Baking sky texture took 21 milliseconds to execute.
20:50:44.492 [dev] Freed 0.00 K bytes of unused textures and uploaded 62.19 Mbytes for 11 newly used texture(s) to GPU memory in 26 ms. GPU memory used for textures : 0.07 GBs.
20:50:44.493 [dev] Light tree build took 0 milliseconds.
20:50:44.494 [dev] Using 1 lights.
20:50:44.496 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 294 MBs (10 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 0 MBs for local results, 2 MBs for look-up tables).
20:50:44.496 [dev] Updating GPU lights took 2 milliseconds to execute.
20:51:02.845 [inf] Scene scale set. One scene unit equals 0.010000 meters.
20:51:02.845 [inf] Scene cleared in 0.00s.
20:51:02.850 [dev] Filling plug-in map took 0.00 seconds.
20:51:02.852 [dev] --------------------------------------------------------------------------------------------------------
20:51:02.852 [dev] Found plug-ins - all scenes (last scene):
20:51:02.852 [dev] 2578 ( 2578) x Node
20:51:02.852 [dev] 693 ( 693) x UVWGenChannel
20:51:02.852 [dev] 692 ( 692) x UVWGenChannel_fast_uvw_tm
20:51:02.852 [dev] 692 ( 692) x UVWGenChannel_crop_0
20:51:02.852 [dev] 674 ( 674) x UVWGenChannel_mode_1
20:51:02.852 [dev] 577 ( 577) x TexBitmap
20:51:02.852 [dev] 556 ( 556) x BitmapBuffer
20:51:02.852 [dev] 505 ( 505) x UVWGenChannel_fast
20:51:02.852 [dev] 505 ( 505) x UVWGenChannel_wrap_different
20:51:02.852 [dev] 464 ( 464) x UVWGenChannel_uvw_tm_is_id
20:51:02.852 [dev] 460 ( 460) x MtlSingleBRDF
20:51:02.852 [dev] 445 ( 445) x GeomStaticMesh
20:51:02.852 [dev] 418 ( 418) x BRDFVRayMtl
20:51:02.852 [dev] 341 ( 341) x MtlMulti
20:51:02.852 [dev] 234 ( 234) x TexCombineColor
20:51:02.852 [dev] 202 ( 202) x TexCombineFloat
20:51:02.852 [dev] 188 ( 188) x UVWGenChannel_slow
20:51:02.852 [dev] 188 ( 188) x UVWGenChannel_wrap_0
20:51:02.852 [dev] 168 ( 168) x TexNormalBump
20:51:02.852 [dev] 140 ( 140) x TexFloatToColor
20:51:02.852 [dev] 113 ( 113) x TexNormalMapFlip
20:51:02.852 [dev] 87 ( 87) x GeomMeshFile
20:51:02.852 [dev] 40 ( 40) x Mtl2Sided
20:51:02.852 [dev] 26 ( 26) x LightIES
20:51:02.852 [dev] 19 ( 19) x UVWGenChannel_mode_0
20:51:02.852 [dev] 17 ( 17) x LightRectangle
20:51:02.852 [dev] 12 ( 12) x BRDFLayered
20:51:02.852 [dev] 12 ( 12) x MtlMaterialID
20:51:02.852 [dev] 8 ( 8) x RawBitmapBuffer
20:51:02.852 [dev] 7 ( 7) x TexAColorChannel
20:51:02.852 [dev] 5 ( 5) x ColorCorrection
20:51:02.852 [dev] 5 ( 5) x TexMaxGamma
20:51:02.852 [dev] 5 ( 5) x TexCompMax
20:51:02.852 [dev] 3 ( 3) x UVWGenRandomizer
20:51:02.852 [dev] 2 ( 2) x BRDFLight
20:51:02.852 [dev] 1 ( 1) x VolumeVRayToon
20:51:02.852 [dev] 1 ( 1) x BRDFScanned
20:51:02.852 [dev] 1 ( 1) x EnvironmentFog
20:51:02.852 [dev] 1 ( 1) x UVWGenChannel_slow_uvw_tm
20:51:02.852 [dev] 1 ( 1) x BRDFBump
20:51:02.852 [dev] 1 ( 1) x RTEngine
20:51:02.852 [dev] 1 ( 1) x RenderView
20:51:02.852 [dev] 1 ( 1) x SunLight
20:51:02.852 [dev] 1 ( 1) x TexSky
20:51:02.852 [dev] 1 ( 1) x InfoRenderEngine
20:51:02.852 [dev] 1 ( 1) x CameraFilmTransform
20:51:02.852 [dev] 1 ( 1) x UVWGenChannel_crop_different
20:51:02.852 [dev] 1 ( 1) x CameraPhysical
20:51:02.852 [dev] 1 ( 1) x VolumeAerialPerspective
20:51:02.852 [dev] 1 ( 1) x RenderChannelDenoiser
20:51:02.852 [dev] 1 ( 1) x FilterLanczos
20:51:02.852 [dev] Loading SettingsUnitsInfo
20:51:02.852 [inf] Scene scale set. One scene unit equals 0.025400 meters.
20:51:02.852 [dev] Loading SettingsOutput
20:51:02.852 [dev] Loading camera.
20:51:02.860 [dev] Loading RenderView (/RenderView) for camera ‘’.
20:51:02.860 [dev] Loading Physical camera (/CameraPhysical) for camera ‘’.
20:51:02.860 [dev] Light plugins found: 44 .
20:51:02.866 [dev] Loading IES file took 6 milliseconds to execute.
20:51:44.996 [inf] Transferring asset: \\10.0.111.2\Projects\Ritchie - Tsawwassen\Reference\ID\BIRDIETRIMLESS-DRAWINGS\BIRDIE TRIMLESS 2700K 500mA.ies
20:51:44.998 [inf] Asset \\10.0.111.2\Projects\Ritchie - Tsawwassen\Reference\ID\BIRDIETRIMLESS-DRAWINGS\BIRDIE TRIMLESS 2700K 500mA.ies not found by the host
20:51:44.998 [ERR] Error loading IES file ‘\\10.0.111.2\Projects\Ritchie - Tsawwassen\Reference\ID\BIRDIETRIMLESS-DRAWINGS\BIRDIE TRIMLESS 2700K 500mA.ies’ : -1: Cannot open IES profile “\\10.0.111.2\Projects\Ritchie - Tsawwassen\Reference\ID\BIRDIETRIMLESS-DRAWINGS\BIRDIE TRIMLESS 2700K 500mA.ies”
20:51:44.998 [dev] Loading IES file took 1 milliseconds to execute.
20:51:44.999 [dev] Lights loaded.
20:51:44.999 [dev] Loading nodes, decals, clippers…
20:51:44.999 [dev] Node plugins found: 2578, decal plugins found: 0, clipper plugins found: 0, volume grid plugins found: 0
20:51:45.112 [inf] Transferring asset: C:\Users\FRITS\Documents\V-Ray Material Library\assets\Metal\Brushed_02_hires_raw.tx
20:51:45.112 [inf] Asset C:\Users\FRITS\Documents\V-Ray Material Library\assets\Metal\Brushed_02_hires_raw.tx not found by the host
20:51:45.112 [ERR] Loading ‘C:\Users\FRITS\Documents\V-Ray Material Library\assets\Metal\Brushed_02_hires_raw.tx’ failed ! Error : cannot open file:[LoadImageHeader] 1: Failed to open file: no such file (1); [LoadImageHeader] 1: Failed to open file: no such file !
20:51:45.118 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Bar_Stool_001_1c492b4d\1c492b4d_3dh_Bar_Stool_001.vrmesh’ | 14.55 thousand Unique vertices | 28.34 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 2 ms | releaseVoxel: 0 ms |
20:51:45.120 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Architecture\Faucet_263_053_5a17c1e6\5a17c1e6_3dh_Faucet_263_053.vrmesh’ | 4.10 thousand Unique vertices | 8.00 thousand Unique faces | 1 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:45.132 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Mug_92-21_4d4a5d07\4d4a5d07_3dh_Coffee_Mug_92-21.vrmesh’ | 4.56 thousand Unique vertices | 9.00 thousand Unique faces | 1 Voxels getVoxel: 2 ms | voxel addGeomDesc: 1 ms | releaseVoxel: 0 ms |
20:51:45.136 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Book_Open_293_009_a6e2e1ff\a6e2e1ff_3dh_Book_Open_293_009.vrmesh’ | 10.32 thousand Unique vertices | 20.63 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 6 ms | releaseVoxel: 0 ms |
20:51:45.137 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Sugar_Bowl_92-21_68b0aa96\68b0aa96_3dh_Coffee_Sugar_Bowl_92-21.vrmesh’ | 6.46 thousand Unique vertices | 12.90 thousand Unique faces | 1 Voxels getVoxel: 3 ms | voxel addGeomDesc: 1 ms | releaseVoxel: 0 ms |
20:51:45.153 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_French_Press_92-21_a6e1de61\a6e1de61_3dh_Coffee_French_Press_92-21.vrmesh’ | 17.43 thousand Unique vertices | 34.39 thousand Unique faces | 1 Voxels getVoxel: 8 ms | voxel addGeomDesc: 7 ms | releaseVoxel: 0 ms |
20:51:45.387 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Pouf_296_012_8461f382\8461f382_3dh_Pouf_296_012.vrmesh’ | 5.83 thousand Unique vertices | 11.66 thousand Unique faces | 1 Voxels getVoxel: 2 ms | voxel addGeomDesc: 1 ms | releaseVoxel: 0 ms |
20:51:45.423 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Rug_002_9785c537\9785c537_3dh_Rug_002.vrmesh’ | 11.00 thousand Unique vertices | 21.70 thousand Unique faces | 1 Voxels getVoxel: 7 ms | voxel addGeomDesc: 3 ms | releaseVoxel: 0 ms |
20:51:45.468 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Armchair_287_004_c3b5e655\c3b5e655_3dh_Armchair_287_004.vrmesh’ | 55.52 thousand Unique vertices | 111.00 thousand Unique faces | 1 Voxels getVoxel: 28 ms | voxel addGeomDesc: 43 ms | releaseVoxel: 0 ms |
20:51:45.470 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Grad_Side_Table_c82cc52d\c82cc52d_3dh_Grad_Side_Table.vrmesh’ | 19.10 thousand Unique vertices | 38.19 thousand Unique faces | 1 Voxels getVoxel: 11 ms | voxel addGeomDesc: 7 ms | releaseVoxel: 0 ms |
20:51:45.496 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Rug_008_4a91787\4a91787_3dh_Rug_008.vrmesh’ | 1.31 thousand Unique vertices | 2.56 thousand Unique faces | 1 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:45.595 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Sofa_296_001_001_ad33ba38\ad33ba38_3dh_Sofa_296_001_001.vrmesh’ | 125.21 thousand Unique vertices | 250.27 thousand Unique faces | 5 Voxels getVoxel: 71 ms | voxel addGeomDesc: 121 ms | releaseVoxel: 11 ms |
20:51:45.702 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Pouf_287_016_b625f289\b625f289_3dh_Pouf_287_016.vrmesh’ | 147.78 thousand Unique vertices | 295.56 thousand Unique faces | 2 Voxels getVoxel: 100 ms | voxel addGeomDesc: 156 ms | releaseVoxel: 2 ms |
20:51:45.790 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Books_296_003_001_985287\985287_3dh_Books_296_003_001.vrmesh’ | 8.07 thousand Unique vertices | 16.09 thousand Unique faces | 6 Voxels getVoxel: 5 ms | voxel addGeomDesc: 2 ms | releaseVoxel: 0 ms |
20:51:45.824 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Books_288_003_002_be91480e\be91480e_3dh_Books_288_003_002.vrmesh’ | 11.64 thousand Unique vertices | 23.22 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 5 ms | releaseVoxel: 0 ms |
20:51:45.836 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Sofa_296_001_002_15b5e971\15b5e971_3dh_Sofa_296_001_002.vrmesh’ | 218.37 thousand Unique vertices | 436.60 thousand Unique faces | 4 Voxels getVoxel: 142 ms | voxel addGeomDesc: 280 ms | releaseVoxel: 4 ms |
20:51:45.884 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Books_288_003_001_963f128c\963f128c_3dh_Books_288_003_001.vrmesh’ | 9.68 thousand Unique vertices | 19.31 thousand Unique faces | 1 Voxels getVoxel: 4 ms | voxel addGeomDesc: 2 ms | releaseVoxel: 0 ms |
20:51:45.914 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Books_287_009_595fb3c1\595fb3c1_3dh_Books_287_009.vrmesh’ | 2.14 thousand Unique vertices | 4.26 thousand Unique faces | 2 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:45.958 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Vase_296_010_002_e0b04048\e0b04048_3dh_Vase_296_010_002.vrmesh’ | 8.42 thousand Unique vertices | 16.83 thousand Unique faces | 1 Voxels getVoxel: 4 ms | voxel addGeomDesc: 2 ms | releaseVoxel: 0 ms |
20:51:45.965 [Wrn] Unsupported translucency mode (5) for BRDF ‘SU|Cosmos|019a50e3-7140-7611-bf99-a6ae9761b326|material|0|/Glass_mtl@mtl__2/Glass_mtl@mtl_brdf__3’ !
20:51:45.973 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Vase_298_010_a9a74103\a9a74103_3dh_Vase_298_010.vrmesh’ | 3.78 thousand Unique vertices | 7.55 thousand Unique faces | 1 Voxels getVoxel: 3 ms | voxel addGeomDesc: 3 ms | releaseVoxel: 0 ms |
20:51:45.980 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Decorative_Vases_001_b4453ebf\b4453ebf_3dh_Decorative_Vases_001.vrmesh’ | 55.30 thousand Unique vertices | 110.59 thousand Unique faces | 2 Voxels getVoxel: 27 ms | voxel addGeomDesc: 31 ms | releaseVoxel: 1 ms |
20:51:45.987 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Vase_296_014_001_c63a0bc2\c63a0bc2_3dh_Vase_296_014_001.vrmesh’ | 1.89 thousand Unique vertices | 3.78 thousand Unique faces | 1 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:45.997 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Books_273_009_4dc70598\4dc70598_3dh_Books_273_009.vrmesh’ | 2.55 thousand Unique vertices | 4.72 thousand Unique faces | 1 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:46.035 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Jug_92-21_e5934b96\e5934b96_3dh_Coffee_Jug_92-21.vrmesh’ | 16.63 thousand Unique vertices | 33.25 thousand Unique faces | 1 Voxels getVoxel: 12 ms | voxel addGeomDesc: 7 ms | releaseVoxel: 0 ms |
20:51:46.048 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Grinder_92-21_965ccc77\965ccc77_3dh_Coffee_Grinder_92-21.vrmesh’ | 23.96 thousand Unique vertices | 47.80 thousand Unique faces | 1 Voxels getVoxel: 12 ms | voxel addGeomDesc: 11 ms | releaseVoxel: 0 ms |
20:51:46.061 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Mug_002_6a0ed4fc\6a0ed4fc_3dh_Coffee_Mug_002.vrmesh’ | 8.53 thousand Unique vertices | 17.06 thousand Unique faces | 1 Voxels getVoxel: 9 ms | voxel addGeomDesc: 8 ms | releaseVoxel: 0 ms |
20:51:46.061 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Coffee_Milk_Jug_92-21_e4d482c7\e4d482c7_3dh_Coffee_Milk_Jug_92-21.vrmesh’ | 14.70 thousand Unique vertices | 29.00 thousand Unique faces | 1 Voxels getVoxel: 8 ms | voxel addGeomDesc: 14 ms | releaseVoxel: 0 ms |
20:51:46.098 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Bowl_296_012_003_65d89076\65d89076_3dh_Bowl_296_012_003.vrmesh’ | 5.95 thousand Unique vertices | 11.90 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 4 ms | releaseVoxel: 0 ms |
20:51:46.100 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Spoon_Little_001_304bfe99\304bfe99_3dh_Spoon_Little_001.vrmesh’ | 1.17 thousand Unique vertices | 2.33 thousand Unique faces | 1 Voxels getVoxel: 1 ms | voxel addGeomDesc: 0 ms | releaseVoxel: 0 ms |
20:51:46.108 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Kettle_61-07_7746f18a\7746f18a_3dh_Kettle_61-07.vrmesh’ | 62.37 thousand Unique vertices | 122.64 thousand Unique faces | 1 Voxels getVoxel: 34 ms | voxel addGeomDesc: 68 ms | releaseVoxel: 1 ms |
20:51:46.111 [inf] Transferring asset: C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\materials\Fabric\maps\Carpet_A_NM.jpg
20:51:46.113 [inf] Asset C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\materials\Fabric\maps\Carpet_A_NM.jpg not found by the host
20:51:46.113 [Wrn] Unsupported nesting of blend material (BRDFLayered) ‘/ASSETS - Fabric Towel/Base’ inside bump material (BRDFBump). Using the base layer.
20:51:46.118 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\People\Marcella_Sitting_001_9ebccabe\9ebccabe_3dh_Marcella_Sitting_001.vrmesh’ | 20.00 thousand Unique vertices | 40.00 thousand Unique faces | 1 Voxels getVoxel: 15 ms | voxel addGeomDesc: 20 ms | releaseVoxel: 0 ms |
20:51:46.235 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Bath_Accessories_005_2bd92007\2bd92007_3dh_Bath_Accessories_005.vrmesh’ | 8.79 thousand Unique vertices | 17.57 thousand Unique faces | 1 Voxels getVoxel: 6 ms | voxel addGeomDesc: 3 ms | releaseVoxel: 0 ms |
20:51:46.238 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Bath_Accessories_006_8521a90c\8521a90c_3dh_Bath_Accessories_006.vrmesh’ | 6.33 thousand Unique vertices | 12.66 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 1 ms | releaseVoxel: 0 ms |
20:51:46.248 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Jug_293_004_b9ed2621\b9ed2621_3dh_Jug_293_004.vrmesh’ | 9.48 thousand Unique vertices | 18.96 thousand Unique faces | 1 Voxels getVoxel: 5 ms | voxel addGeomDesc: 2 ms | releaseVoxel: 0 ms |
20:51:46.280 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Bag_159_062_1b2dc033\1b2dc033_3dh_Bag_159_062.vrmesh’ | 11.22 thousand Unique vertices | 22.45 thousand Unique faces | 1 Voxels getVoxel: 7 ms | voxel addGeomDesc: 5 ms | releaseVoxel: 0 ms |
20:51:46.290 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Pitcher_001_ef90f527\ef90f527_3dh_Pitcher_001.vrmesh’ | 30.85 thousand Unique vertices | 61.40 thousand Unique faces | 3 Voxels getVoxel: 18 ms | voxel addGeomDesc: 15 ms | releaseVoxel: 0 ms |
20:51:46.348 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Laptop_288_002_af68bbef\af68bbef_3dh_Laptop_288_002.vrmesh’ | 33.17 thousand Unique vertices | 65.58 thousand Unique faces | 1 Voxels getVoxel: 17 ms | voxel addGeomDesc: 31 ms | releaseVoxel: 1 ms |
20:51:46.370 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Phone_288_005_2c5353a0\2c5353a0_3dh_Phone_288_005.vrmesh’ | 31.93 thousand Unique vertices | 63.68 thousand Unique faces | 1 Voxels getVoxel: 18 ms | voxel addGeomDesc: 42 ms | releaseVoxel: 0 ms |
20:51:46.502 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Giant_Feather_Grass_001_21948ac\21948ac_3dh_Giant_Feather_Grass_001.vrmesh’ | 24.13 thousand Unique vertices | 26.93 thousand Unique faces | 1 Voxels getVoxel: 11 ms | voxel addGeomDesc: 25 ms | releaseVoxel: 0 ms |
20:51:46.506 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Giant_Feather_Grass_003_c04bde33\c04bde33_3dh_Giant_Feather_Grass_003.vrmesh’ | 27.38 thousand Unique vertices | 32.00 thousand Unique faces | 1 Voxels getVoxel: 17 ms | voxel addGeomDesc: 32 ms | releaseVoxel: 1 ms |
20:51:46.542 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Giant_Feather_Grass_002_b4a23d91\b4a23d91_3dh_Giant_Feather_Grass_002.vrmesh’ | 25.48 thousand Unique vertices | 28.02 thousand Unique faces | 1 Voxels getVoxel: 21 ms | voxel addGeomDesc: 30 ms | releaseVoxel: 2 ms |
20:51:46.544 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Furniture\Rua_Ipanema_Standard_Height_96fc0280\96fc0280_3dh_Rua_Ipanema_Standard_Height.vrmesh’ | 204.52 thousand Unique vertices | 374.61 thousand Unique faces | 1 Voxels getVoxel: 198 ms | voxel addGeomDesc: 906 ms | releaseVoxel: 7 ms |
20:51:46.577 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Comptonia_peregrina_004_9d7e0ed7\9d7e0ed7_3dh_Comptonia_peregrina_004.vrmesh’ | 126.62 thousand Unique vertices | 160.15 thousand Unique faces | 1 Voxels getVoxel: 56 ms | voxel addGeomDesc: 191 ms | releaseVoxel: 2 ms |
20:51:46.812 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Triodia_scariosa_003_cce54f5e\cce54f5e_3dh_Triodia_scariosa_003.vrmesh’ | 62.00 thousand Unique vertices | 88.26 thousand Unique faces | 1 Voxels getVoxel: 53 ms | voxel addGeomDesc: 123 ms | releaseVoxel: 1 ms |
20:51:46.871 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Chinese_Lilyurf_005_f12f56fe\f12f56fe_3dh_Chinese_Lilyurf_005.vrmesh’ | 66.95 thousand Unique vertices | 71.07 thousand Unique faces | 1 Voxels getVoxel: 32 ms | voxel addGeomDesc: 108 ms | releaseVoxel: 1 ms |
20:51:46.911 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Astrebla_lappacea_001_ccec1d33\ccec1d33_3dh_Astrebla_lappacea_001.vrmesh’ | 115.16 thousand Unique vertices | 199.98 thousand Unique faces | 1 Voxels getVoxel: 83 ms | voxel addGeomDesc: 257 ms | releaseVoxel: 3 ms |
20:51:46.932 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Comptonia_peregrina_003_3d04b758\3d04b758_3dh_Comptonia_peregrina_003.vrmesh’ | 220.00 thousand Unique vertices | 277.88 thousand Unique faces | 1 Voxels getVoxel: 116 ms | voxel addGeomDesc: 488 ms | releaseVoxel: 5 ms |
20:51:46.943 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Miscanthus_sinensis_Gracillimus_005_9c4004ec\9c4004ec_3dh_Miscanthus_sinensis_Gracillimus_005.vrmesh’ | 188.46 thousand Unique vertices | 191.82 thousand Unique faces | 1 Voxels getVoxel: 97 ms | voxel addGeomDesc: 299 ms | releaseVoxel: 6 ms |
20:51:46.945 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Pennisetum_setaceum_004_c94a74bc\c94a74bc_3dh_Pennisetum_setaceum_004.vrmesh’ | 127.01 thousand Unique vertices | 167.78 thousand Unique faces | 1 Voxels getVoxel: 88 ms | voxel addGeomDesc: 277 ms | releaseVoxel: 2 ms |
20:51:46.950 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Paper_Birch_001_Spring_5d29aeb4\5d29aeb4_3dh_Paper_Birch_001_Spring.vrmesh’ | 151.24 thousand Unique vertices | 240.83 thousand Unique faces | 1 Voxels getVoxel: 95 ms | voxel addGeomDesc: 454 ms | releaseVoxel: 6 ms |
20:51:46.955 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Ammophila_brevilugatta_004_81cb4ecf\81cb4ecf_3dh_Ammophila_brevilugatta_004.vrmesh’ | 114.50 thousand Unique vertices | 162.56 thousand Unique faces | 1 Voxels getVoxel: 82 ms | voxel addGeomDesc: 226 ms | releaseVoxel: 2 ms |
20:51:46.999 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Paper_Birch_002_Spring_40775276\40775276_3dh_Paper_Birch_002_Spring.vrmesh’ | 178.23 thousand Unique vertices | 291.29 thousand Unique faces | 1 Voxels getVoxel: 133 ms | voxel addGeomDesc: 479 ms | releaseVoxel: 6 ms |
20:51:47.028 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Chinese_Lilyurf_006_e7d76e31\e7d76e31_3dh_Chinese_Lilyurf_006.vrmesh’ | 55.80 thousand Unique vertices | 56.06 thousand Unique faces | 1 Voxels getVoxel: 22 ms | voxel addGeomDesc: 61 ms | releaseVoxel: 1 ms |
20:51:47.034 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Enteropogon_acicularis_003_f1e7677f\f1e7677f_3dh_Enteropogon_acicularis_003.vrmesh’ | 156.94 thousand Unique vertices | 199.97 thousand Unique faces | 1 Voxels getVoxel: 109 ms | voxel addGeomDesc: 325 ms | releaseVoxel: 3 ms |
20:51:47.042 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Hakonechloa_Macra_Green_Forest_Grass_001_bc669e0\bc669e0_3dh_Hakonechloa_Macra_Green_Forest_Grass_001.vrmesh’ | 211.44 thousand Unique vertices | 312.44 thousand Unique faces | 1 Voxels getVoxel: 123 ms | voxel addGeomDesc: 510 ms | releaseVoxel: 5 ms |
20:51:47.043 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Chinese_Lilyurf_004_5e6d6a0e\5e6d6a0e_3dh_Chinese_Lilyurf_004.vrmesh’ | 55.92 thousand Unique vertices | 55.65 thousand Unique faces | 1 Voxels getVoxel: 26 ms | voxel addGeomDesc: 55 ms | releaseVoxel: 1 ms |
20:51:47.043 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Astrebla_lappacea_002_591116ec\591116ec_3dh_Astrebla_lappacea_002.vrmesh’ | 180.96 thousand Unique vertices | 316.71 thousand Unique faces | 1 Voxels getVoxel: 126 ms | voxel addGeomDesc: 396 ms | releaseVoxel: 5 ms |
20:51:47.058 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Arenaria_verna_002_6ae4e221\6ae4e221_3dh_Arenaria_verna_002.vrmesh’ | 110.72 thousand Unique vertices | 111.78 thousand Unique faces | 1 Voxels getVoxel: 83 ms | voxel addGeomDesc: 226 ms | releaseVoxel: 1 ms |
20:51:47.208 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Arenaria_verna_003_343bf36a\343bf36a_3dh_Arenaria_verna_003.vrmesh’ | 157.47 thousand Unique vertices | 172.63 thousand Unique faces | 1 Voxels getVoxel: 82 ms | voxel addGeomDesc: 301 ms | releaseVoxel: 2 ms |
20:51:47.213 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\People\00055_Paul_Jan_006_e2050af1\e2050af1_3dh_00055_Paul_Jan_006.vrmesh’ | 20.42 thousand Unique vertices | 40.84 thousand Unique faces | 1 Voxels getVoxel: 25 ms | voxel addGeomDesc: 125 ms | releaseVoxel: 0 ms |
20:51:47.246 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Hakonechloa_Macra_Green_Forest_Grass_002_950a856d\950a856d_3dh_Hakonechloa_Macra_Green_Forest_Grass_002.vrmesh’ | 267.21 thousand Unique vertices | 393.49 thousand Unique faces | 1 Voxels getVoxel: 171 ms | voxel addGeomDesc: 643 ms | releaseVoxel: 6 ms |
20:51:47.258 [inf] Transferring asset: SONNENSC.PNG
20:51:47.265 [inf] Asset SONNENSC.PNG not found by the host
20:51:47.268 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Dryas_octopetala_005_9938b09b\9938b09b_3dh_Dryas_octopetala_005.vrmesh’ | 117.56 thousand Unique vertices | 163.52 thousand Unique faces | 1 Voxels getVoxel: 65 ms | voxel addGeomDesc: 223 ms | releaseVoxel: 2 ms |
20:51:47.285 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Dryas_octopetala_006_34527cde\34527cde_3dh_Dryas_octopetala_006.vrmesh’ | 166.71 thousand Unique vertices | 232.23 thousand Unique faces | 1 Voxels getVoxel: 105 ms | voxel addGeomDesc: 297 ms | releaseVoxel: 3 ms |
20:51:47.400 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Arenaria_verna_004_464208a\464208a_3dh_Arenaria_verna_004.vrmesh’ | 272.28 thousand Unique vertices | 281.02 thousand Unique faces | 1 Voxels getVoxel: 192 ms | voxel addGeomDesc: 520 ms | releaseVoxel: 6 ms |
20:51:47.500 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Arenaria_verna_005_873914b2\873914b2_3dh_Arenaria_verna_005.vrmesh’ | 289.90 thousand Unique vertices | 313.00 thousand Unique faces | 1 Voxels getVoxel: 202 ms | voxel addGeomDesc: 584 ms | releaseVoxel: 8 ms |
20:51:47.551 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Astrebla_lappacea_003_5d78f6c3\5d78f6c3_3dh_Astrebla_lappacea_003.vrmesh’ | 385.82 thousand Unique vertices | 674.93 thousand Unique faces | 1 Voxels getVoxel: 305 ms | voxel addGeomDesc: 694 ms | releaseVoxel: 9 ms |
20:51:47.639 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Watch_156_033_7392017f\7392017f_3dh_Watch_156_033.vrmesh’ | 432.79 thousand Unique vertices | 860.77 thousand Unique faces | 1 Voxels getVoxel: 312 ms | voxel addGeomDesc: 1012 ms | releaseVoxel: 11 ms |
20:51:47.648 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Hakonechloa_Macra_Green_Forest_Grass_004_c622e303\c622e303_3dh_Hakonechloa_Macra_Green_Forest_Grass_004.vrmesh’ | 369.95 thousand Unique vertices | 550.44 thousand Unique faces | 1 Voxels getVoxel: 240 ms | voxel addGeomDesc: 962 ms | releaseVoxel: 12 ms |
20:51:47.662 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Acer_griseum_001_fdeade00\fdeade00_3dh_Acer_griseum_001.vrmesh’ | 247.42 thousand Unique vertices | 284.26 thousand Unique faces | 1 Voxels getVoxel: 145 ms | voxel addGeomDesc: 474 ms | releaseVoxel: 5 ms |
20:51:47.685 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Accessories\Bag_156_012_26e68836\26e68836_3dh_Bag_156_012.vrmesh’ | 361.67 thousand Unique vertices | 692.32 thousand Unique faces | 1 Voxels getVoxel: 265 ms | voxel addGeomDesc: 1125 ms | releaseVoxel: 10 ms |
20:51:47.775 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Architecture\Bath_Tap_127_007_cd563d1b\cd563d1b_3dh_Bath_Tap_127_007.vrmesh’ | 15.14 thousand Unique vertices | 29.86 thousand Unique faces | 1 Voxels getVoxel: 25 ms | voxel addGeomDesc: 43 ms | releaseVoxel: 0 ms |
20:51:47.877 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Architecture\Zen_Bath_001_ed5ba81a\ed5ba81a_3dh_Zen_Bath_001.vrmesh’ | 54.55 thousand Unique vertices | 108.90 thousand Unique faces | 1 Voxels getVoxel: 33 ms | voxel addGeomDesc: 106 ms | releaseVoxel: 1 ms |
20:51:47.944 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Astrebla_lappacea_004_8b9f87da\8b9f87da_3dh_Astrebla_lappacea_004.vrmesh’ | 490.25 thousand Unique vertices | 853.98 thousand Unique faces | 1 Voxels getVoxel: 405 ms | voxel addGeomDesc: 965 ms | releaseVoxel: 11 ms |
20:51:48.245 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Comptonia_peregrina_005_dec1c055\dec1c055_3dh_Comptonia_peregrina_005.vrmesh’ | 643.02 thousand Unique vertices | 812.19 thousand Unique faces | 1 Voxels getVoxel: 382 ms | voxel addGeomDesc: 1475 ms | releaseVoxel: 17 ms |
20:51:48.285 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Pine_Tree_98-37_f616c4a4\f616c4a4_3dh_Pine_Tree_98-37.vrmesh’ | 141.17 thousand Unique vertices | 107.85 thousand Unique faces | 1 Voxels getVoxel: 68 ms | voxel addGeomDesc: 208 ms | releaseVoxel: 1 ms |
20:51:48.436 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Black_Gum_002_Spring_d75bdcd7\d75bdcd7_3dh_Black_Gum_002_Spring.vrmesh’ | 150.34 thousand Unique vertices | 230.47 thousand Unique faces | 1 Voxels getVoxel: 117 ms | voxel addGeomDesc: 323 ms | releaseVoxel: 3 ms |
20:51:48.491 [dev] Nodes and decals loaded in 3.49 seconds.
20:51:48.491 [dev] Instancer plugins found: 0
20:51:48.491 [dev] Instancers loaded in 0.00 seconds.
20:51:48.491 [dev] VRayScene plugins found: 0
20:51:48.491 [dev] VRayScenes loaded in 0.00 seconds.
20:51:48.491 [dev] Loading object connections…
20:51:48.492 [dev] Object connections loaded in 0.00 seconds.
20:51:48.632 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Austrostipa_ramosissima_003_d4243d86\d4243d86_3dh_Austrostipa_ramosissima_003.vrmesh’ | 738.58 thousand Unique vertices | 917.28 thousand Unique faces | 1 Voxels getVoxel: 487 ms | voxel addGeomDesc: 1501 ms | releaseVoxel: 17 ms |
20:51:48.644 [inf] Loaded ‘D:\Chaos Cosmos\UserPackages\3D_Models\AI-Generated\Peloton_Tread_85d47f2e\85d47f2e_3dh_Peloton_Tread.vrmesh’ | 553.22 thousand Unique vertices | 999.89 thousand Unique faces | 1 Voxels getVoxel: 412 ms | voxel addGeomDesc: 1198 ms | releaseVoxel: 12 ms |
20:51:48.683 [ERR] Loading ‘C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\materials\Fabric\maps\Carpet_A_NM.jpg’ failed ! Error : cannot open file:[LoadImageHeader] 1: Failed to open file: no such file (1); [LoadImageHeader] 1: Failed to open file: no such file !
20:51:48.832 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Viburnum_opulus_003_94a042fd\94a042fd_3dh_Viburnum_opulus_003.vrmesh’ | 332.21 thousand Unique vertices | 417.56 thousand Unique faces | 1 Voxels getVoxel: 228 ms | voxel addGeomDesc: 544 ms | releaseVoxel: 8 ms |
20:51:48.926 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Peony_19-03_a4ee5a01\a4ee5a01_3dh_Peony_19-03.vrmesh’ | 420.87 thousand Unique vertices | 531.50 thousand Unique faces | 1 Voxels getVoxel: 291 ms | voxel addGeomDesc: 643 ms | releaseVoxel: 8 ms |
20:51:49.071 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Mexican_Feather_Grass_001_512feb20\512feb20_3dh_Mexican_Feather_Grass_001.vrmesh’ | 987.09 thousand Unique vertices | 1.24 million Unique faces | 1 Voxels getVoxel: 597 ms | voxel addGeomDesc: 1993 ms | releaseVoxel: 18 ms |
20:51:49.209 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Mexican_Feather_Grass_002_dfa87ece\dfa87ece_3dh_Mexican_Feather_Grass_002.vrmesh’ | 989.45 thousand Unique vertices | 1.24 million Unique faces | 1 Voxels getVoxel: 647 ms | voxel addGeomDesc: 2073 ms | releaseVoxel: 24 ms |
20:51:49.624 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Mexican_Feather_Grass_003_363ade8a\363ade8a_3dh_Mexican_Feather_Grass_003.vrmesh’ | 1.08 million Unique vertices | 1.35 million Unique faces | 1 Voxels getVoxel: 698 ms | voxel addGeomDesc: 2409 ms | releaseVoxel: 16 ms |
20:51:50.085 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vegetation\Honey_Locust_007_Autumn_9d932754\9d932754_3dh_Honey_Locust_007_Autumn.vrmesh’ | 948.73 thousand Unique vertices | 985.56 thousand Unique faces | 1 Voxels getVoxel: 552 ms | voxel addGeomDesc: 1450 ms | releaseVoxel: 12 ms |
20:51:50.275 [inf] Loaded scanned material ‘D:\Chaos Cosmos\Packages\Materials\Metal\Metal_Matte_007_9_93cm_303eae4e\303eae4e_Metal_Matte_007_9.93cm.vrscan’: 54 lights, 109 views, 9.9x9.9 cm, 307.8 MB GPU blob (3138 ms)
20:51:51.829 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vehicles\Car_036_cfc51090\cfc51090_3dh_Car_036.vrmesh’ | 2.09 million Unique vertices | 4.07 million Unique faces | 1 Voxels getVoxel: 1613 ms | voxel addGeomDesc: 3065 ms | releaseVoxel: 41 ms |
20:51:52.567 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vehicles\Motorcycle_004_bc9a454f\bc9a454f_3dh_Motorcycle_004.vrmesh’ | 1.41 million Unique vertices | 2.74 million Unique faces | 1 Voxels getVoxel: 2309 ms | voxel addGeomDesc: 2263 ms | releaseVoxel: 36 ms |
20:51:52.824 [inf] Loaded ‘D:\Chaos Cosmos\Packages\3D_Models\Vehicles\Motorcycle_002_68702863\68702863_3dh_Motorcycle_002.vrmesh’ | 2.03 million Unique vertices | 3.96 million Unique faces | 1 Voxels getVoxel: 2246 ms | voxel addGeomDesc: 2573 ms | releaseVoxel: 56 ms |
20:51:52.825 [dev] Computing scene bounding box took 0.00 seconds.
20:51:52.826 [dev] Loading global light level.
20:51:52.827 [dev] Loading animation…
20:51:52.827 [dev] Animation loaded in 0.00 seconds.
20:51:52.827 [inf] Loaded ‘’ | 44 Lights | 2.25 thousand Nodes | 22.26 million Unique vertices | 31.67 million Unique faces | 104 Voxels
20:51:52.827 [inf] Loading scene took 49.98 seconds !
20:51:54.473 [ERR] Loading ‘SONNENSC.PNG’ failed ! Error : cannot open file:[LoadImageHeader] 1: Failed to open file: no such file (1); [LoadImageHeader] 1: Failed to open file: no such file !
20:51:57.868 [dev] Copying geometry data to GPU took 5031 ms.
20:51:57.869 [dev] Building and compacting BLAS buffers…
20:51:58.086 [dev] Build schedule : 118 ms (buffers : 103 ms, command (CPU) : 13 ms); Build command (GPU) : 55 ms.
20:51:58.086 [dev] Compacting BLAS buffers took 40 ms and saved 915.38 Mbytes on the GPU ( 56.87 % ), required additional 367.50 Mbytes during compaction.
20:51:58.086 [dev] BLAS build and compact took 216 ms for 535 BLASes.
20:51:58.262 [dev] Light tree build took 0 milliseconds.
20:51:58.263 [dev] Using 42 lights.
20:51:58.265 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 291 MBs (7 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 0 MBs for local results, 2 MBs for look-up tables).
20:51:58.265 [dev] Updating GPU lights took 52 milliseconds to execute.
20:51:58.271 [dev] TLAS build took 4 ms !
20:51:58.274 [dev] Memory for all 452 shading graphs : 261.38 KBytes.
20:51:58.275 [inf] (NVIDIA GeForce RTX 4080 SUPER) Internal buffers size : 292 MBs (7 MBs for shadows, 233 MBs for path state, 49 MBs for hit state, 2 MBs for local results, 2 MBs for look-up tables).
20:51:58.275 [dev] Shading graph local result slots per thread changed to 12.
20:51:58.276 [inf] Loaded 531 8-bit textures from disk using 10.78 GBs of additional CPU memory.
20:51:58.276 [inf] Texture loading wait : 0.00s. Load : 151.27s. Build mipmaps : 208.78s (0.00s idle). CPU memory used for textures : 10.85 GBs.
20:51:58.278 [dev] Geometry mem | GPU dedicated : 1.37 G ( 1.39 G alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 1.37 G ( 1.39 G alloced) | CPU : 1.54 G |
20:51:58.278 [dev] Instance mem | GPU dedicated : 505.43 K ( 512.00 K alloced) | GPU shared : 505.43 K ( 512.00 K alloced) | GPU total : 1010.86 K ( 1.00 M alloced) | CPU : 1.04 M |
20:51:58.279 [dev] BLAS mem | GPU dedicated : 804.64 M ( 807.25 M alloced) | GPU shared : 0.00 K ( 0.00 K alloced) | GPU total : 804.64 M ( 807.25 M alloced) |
20:51:58.279 [dev] TLAS mem | GPU dedicated : 733.25 K ( 832.00 K alloced) | GPU shared : 141.88 K ( 192.00 K alloced) | GPU total : 875.12 K ( 1.00 M alloced) |
20:51:58.281 [dev] Total geom mem | GPU dedicated : 2.16 G ( 2.18 G alloced) | GPU shared : 647.30 K ( 704.00 K alloced) | GPU total : 2.16 G ( 2.18 G alloced) | CPU : 1.54 G |
20:51:58.281 [inf] Process Dedicated | Budget : 14.92 G, Usage : 3.86 G, Available for reservation : 7.59 G, Current reservation : 0.00 K
20:51:58.281 [inf] Process Shared | Budget : 15.22 G, Usage : 688.96 M, Available for reservation : 7.74 G, Current reservation : 0.00 K
20:51:58.281 [dev] --------------------------------------------------------------------------------------------------------
20:51:58.281 [dev] ------------------------ Memory Manager State
20:51:58.281 [dev] 0.00 Kbytes in 0 free heaps.
20:51:58.281 [dev] Tier ’ Forever’ | heaps : 25 | free ranges : 3 | total : 1.56 Gbytes | free : 49.19 Mbytes | largest range : 48.50 Mbytes
20:51:58.281 [dev] Tier ’ Frame’ | heaps : 1 | free ranges : 1 | total : 64.00 Mbytes | free : 63.38 Mbytes | largest range : 63.38 Mbytes
20:51:58.281 [dev] Tier ’ Temp0’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:51:58.281 [dev] Tier ’ Temp1’ | heaps : 0 | free ranges : 0 | total : 0.00 Kbytes | free : 0.00 Kbytes | largest range : 0.00 Kbytes
20:51:58.281 [dev] Total managed memory : 1.62 Gbytes !
20:51:58.281 [dev] Light cache factor set to 4.17
20:51:58.465 [dev] Light cache factor set to 3.33
20:51:58.966 [dev] Creating lights’ UI took 0.47 seconds.
20:51:58.991 [dev] Baking sky texture took 22 milliseconds to execute.
20:51:59.274 [dev] Freed 0.00 K bytes of unused textures and uploaded 578.25 Mbytes for 533 newly used texture(s) to GPU memory in 283 ms. GPU memory used for textures : 0.63 GBs.
20:51:59.385 [inf] Uploaded 1 scanned material to the GPU (307.8 MB).
20:51:59.450 [dev] Light tree build took 0 milliseconds.
20:51:59.451 [dev] Using 42 lights.
20:51:59.451 [dev] Updating GPU lights took 1 milliseconds to execute.
20:51:59.562 [dev] Freed 2.81 Mbytes of unused textures and uploaded 14.75 Mbytes for 45 newly used texture(s) to GPU memory in 58 ms. GPU memory used for textures : 0.64 GBs.
20:52:20.872 [dev] Creating lights’ UI took 0.00 seconds.
20:52:21.052 [dev] Light cache factor set to 3.33
20:52:21.194 [dev] Freed 7.00 Mbytes of unused textures and uploaded 8.88 Mbytes for 64 newly used texture(s) to GPU memory in 22 ms. GPU memory used for textures : 0.64 GBs.
There are a couple of red warnings but nothing to do with sunlight.
Yellow
RED
No warning about a missing object, we will have to investigate.
Thank you for the detailed steps @NRH1981 !
I was able to reproduce the issue and linked your post to internal bug report LAV-2913.
Unfortunately, for now I was not able to find any suitable workaround with Live Link I could suggest.
We will update you if there is any change.
Thanks @natalia.gruzdova and @vladimir.nedev
Would be great if you can find a solution to this issue soon, it really limits how we can use vantage if the individual scene setups cannot be recalled as it takes a while to recreate each time.
Hopefully you can find why this is not saving and patch it soon.
The issue we found affects only the Sun light btw (that’s where “geolocation, custom time of day, coordinates” are). The fix will be for that.
@vladimir.nedev
Understood,
As i say i hope it is patched soon, having to reset 30+ scenes with specific time of day, and geolocation information takes a long time to recreate and is not workable.
Thank you as always for addressing these issues.
Would love to see a hotfix for 3.4 instead of waiting for 3.5, which I’m guessing is months away? Would it be possible to get this bug fixed before the next major release?
The team decided to skip 3.4.1 and go straight to 3.5.0. It’s planned for early November.
Great! It would be nice if we could get advance notice each time, including an estimated release date and a sneak peek for the next update.
Hey NPG,
Do you have any info if this will be fixed on the 3.5 release? (and is this still the plan, I see 3.4.1 patch came out today) I had hoped it might be fixed on the 3.4.1 release notes today but alas not. :frowning: Got my hopes up…
Yes, the current plan is to have this fixed in 3.5 coming later this month, probably the end of the month. The initial plans changed a bit.
Hi Vlad,
This is great news. Looking forward to the new release soon, can’t come soon enough! :slight_smile:
