Vantage command line options
Expermenting with command line + cmdjob + backburener rendering here. Figured out a simple way to submit jobs to backburner and it works fine. The problem is that there’s no obvious way to control some critical parameters (e.g. denoiser type, render elements, etc.). Tried loading .vantage file with set parameters instead of .vrscene, tired editing vantage.ini (to change denoiser type). Does not seem to work. Any way to access these parameters? Or are we limited to only those listed in vantage_console.exe -help?
.vantage files store render tasks with all the crucial parameters:
“render_settings”: {
“render_tasks”: [{
“first_frame”: 0,
“final_frame”: 150,
“frame_step”: 1,
“total_frames”: 151,
“camera_type”: 0,
“output_width”: 1280,
“output_height”: 720,
“output_types”: 1,
“denoiser_type”: 3,
“max_frame_samples”: 200,
“quality_preset”: 4,
“render_elements”: 16388,
“fps”: 30.0,
“spin_ortho_width”: 1000.0,
“fov_x”: 6.2831854820251469,
“fov_y”: 3.1415927410125734,
“eye_dist_mm”: 65.0,
“rotation_focus”: false,
“stereo_top_bottom”: false,
“use_light_cache”: true,
“responsive_desktop”: false,
“use_auto_exposure”: false,
“use_denoiser”: true,
“reduce_flickering”: false,
“use_motion_blur”: false,
“save_png_alpha”: false,
“bake_collor_corrections_in_exr”: false,
“denoiser_final_pass”: true,
“elements_in_separate_files”: true,
“task_enabled”: true,
“task_name”: “Render Task 1”,
“output_file”: “C:\output_.png”,
“task_scene_state”: “CURRENT”,
“dialog_scene_state”: “”
Would be very useful to have a vantage_console.exe command to initiate rendering of a stored render task.
Hey,
Thanks a lot for the suggestion. Currently the command line access is a bit limited as you have noticed. We certainly would like to explore improving that in the future.
Any chances we’d get this functionality on the next update?
Managed to make a clumsy workaround with pywinauto. A simple python script can open a .vantage scene with a stored render task in vantage.exe, start the render queue and close the program when it finishes rendering. This is submitted as a render job to backburner. So it kind of gets the job done for now. But there are still some problems we may run into like d3d errors that would keep the process stopped until a human interferes. etc.
So just curious to know if the wait will be long and it’s worth to further develop our inhouse workarounds or could we possibly expect at least this simple functionality in vantage_console.exe sooner rather than later? It really is vital in almost any production pipeline.
I’m working on a similar automation workflow and would appreciate any advice on the supported approach.
I’m creating animated Gaussian splats of machinery using renders from 3ds Max and Vantage. For each animation frame, I capture the frozen machine state from a rig of 642 cameras. My current test covers frames 2–9, producing 5,136 images at 1920 × 1920. but future projects may require more frames and potentially 100’s of machine to output so this needs to be automated to make it feasable.
I’m using Vantage 3.3.1, 3ds Max 2026 and an RTX 4090 on one Windows workstation.
A Max script exports a separate .vrscene for each animation frame, together with a .vantage configuration containing the camera render tasks. A Python controller then loads each scene, renders its cameras and advances to the next scene.
Individual CLI renders work, but I haven’t found a way to execute the complete saved camera queue through the CLI while keeping the scene loaded. My current workaround automates the Start Queue button. It works, but depends on window focus and appearance checks, which have caused unattended runs to stop. I’d like to replace that GUI interaction with a supported command.
Could you clarify:
  1. Is there a CLI option to execute all enabled render_tasks from a .vantage file, retaining their camera and render settings?
  2. Alternatively, can a running Vantage instance accept successive camera-render commands without reloading the scene?
  3. Is there a reliable status or completion event for scene readiness, render start and queue completion?
  4. Is support for starting saved queues planned for an upcoming release?
I can provide a small reproduction package, controller details and logs if helpful.
Thanks,
Andrew
Hi Andrew,
I believe some of your points and requests are already on our to-do list. However, we will review and discuss your feedback with our product managers and keep you updated on any new information.
