vantage crash
when i run “render high quality snapshot” many times(changing different scenes,changing different resolutions) , if I click quickly ,vantage crash irregularly. any Helps.
Hi max_romju
As the message suggest the available GPU memory is insufficient for the resolution you input. What are your hardware specs and at what resolution are you rendering between scenes?
Alexander
wise counsel. thank you very much
You can also have a look at the memory statistic part of this video here:
Simeon
