Hola, estoy teniendo problemas al momento de renderizar en vantage, pensé que podía ser mi escena e intenté con una escena muy sencilla que solo tiene una caja, un plano, una luz y una cámara animada, lo mando a vantage mediante el button “vantage animation export”, y en vantage le doy en start después de configurar y el render nunca empieza, esta prueba la estoy haciendo porque tengo una escena mucho más compleja y ya chequé y no tiene problemas y por eso quise probar con una escena simple. Espero su respuesta, gracias.
Hello, please use English on the forum ![]()
Did I understand correctly from the translation of your post that this problem happens with the simple scene but it does NOT happen with the complex scene that you have?
Are there relevant messages in the MaxScript listener window in 3dsMax and in Vantage’s debug log (Help->Open debug log) ?
Sorry, this problem happens with the simple and complex scene, i did the simple one because i wanted to check if it was something wrong with the complex one but is the same, when i wanted to render in vantage it just appears the message that its going to start to render but it never starts, there are any relevant messages and btw i used the complex scene in november and everything worked great, so i dont know whats going on now
What are the exact versions of Vantage and V-Ray for 3ds Max that you’re using? Did you update any of them since November? If it worked with the versions from November you could try downloading the older version again - there is a “view older versions” link on the download page.
This is not a known issue, so I’m not sure what else to suggest. Check the messages in the Vantage debug log and Maxscript listener for warnings or errors.
i have 3ds max 2024, Corona 14 update 1 and corona vantage 3.1, i will try downloading previous versions and ill let you know if it works, thanks
So i changed all my programs back to the versions i had in november and that’s the only way it worked. The worst part is that before I had only tried to do it with one program, but now i know that I had to do it with all of them, at the end it worked, thank you!
Glad you are no longer blocked by this, but it is only a workaround. Ideally we should isolate which update (Corona or Vantage, etc.) caused the issue so we can find the cause and fix it for future updates.
