Vantage sequence frame mode does not support particles of tyflow
I use the first mode to render the particles of tyflow in a single sheet, but when I use the sequence frame animation, that is, the third mode, vantage can’t recognize the particles, so it can’t output the relevant particle animation. Is it that the current software doesn’t support it, or is there a problem with my setting? Thank you
Hi gong_xiaochen,
Are you using to render the animation via Live link or are exporting it to vrscene and then loading it in Vantage? Also can you please send a simple sample scene so we can investigate?
Alexander
Hello, I use this function
,And how can I provide you with my documents? To your email? thank you
Hi gong_xiaochen,
From the screen shot I see that those are the outdated versions and you are missing the ‘Render animation with Chaos Vantage’ button. Which version of Vantage are you using? Can you please update to the latest (currently 1.6.2) and try to render the tyflow animation using the ‘Render animation with Chaos Vantage’. The Export and send the current animation range as a .vrscene to Chaos Vantage doesn’t support certain animated deformations which I believe is the case here. We will be adding support for those in the future (no ETA at the moment) but for the time please try with the ‘Render animation with Chaos Vantage’ method.
Alexander
