Vantage(vrscene) export file saved where?
Hi
for some reason i need to find the exported file for vanatge export.
is there a documentation or a setting maybe even, where this file is saved on disc?
i assume it is a vrscene file saved in some prefs or ap /roaming folder?
great would be a setting where to save the file(like to another disc)
thx for info
Stefan
ok never mind i found it. seems this is no vrscene as i expected, nut an huge number of .cgb mesh files
You can specify where it gets saved, so it does depend on which option you are using to send the scene to Vantage. The recommended way is the one where you do pick the file location, rather than have the system do it for you - see https://youtu.be/DDvZD75W7D4?si=Q-N3BLpCySeP3lYT&t=237
