VDB Files without density channel
Hello there.
I have a smoke simulation from Phoenix FD in VDB sequence, and now i want to import using Arnold for Cinema 4D, but there is no density channel. Using the other channels doesnt do nothing :frowning: and i cant render the simulation in Arnold. Is ther a way to get to render in Arnold ?
If you set Smoke_phx to be used as a density channel it should work.
Hi Georgi,
Tks for your reply, already tried all the channels as density but stil cant get it to work.
Probably the Arnold guys would be able to help then.
