Vectorworks 2025 compatibility
Is Vectorworks 2025 officialy supported?
Yesterday release 2025 has been released, now installed but we cannot find Enscape menu commands in workspace …?
Hi @drelarch , Vectorworks 2025 is not yet officially supported but will be with our next upcoming service pack in around a week. Feel free to stay tuned for further news in that regard, I’ll also notify you once more after 4.1.1 has come out including support for VW 25.
Ok, great.
Thank you!
Demian
I just tried to install Enscape with Vectorworks 2025 and it doesn’t seem to be working. Is it still not supported?
Welcome to our Forum @alexdashsawyer .
My apologies for any confusion caused here in regards to the time of release but Enscape Service Pack 4.1.1 will actually come out later today also including Vectorworks 2025 support.
Feel free to stay tuned for an update thread in our News&FAQ section within the next hours.
@alexdashsawyer , Enscape 4.1.1 Service Pack is out now with VW 2025 support: Enscape 4.1.1 Service Pack Released
I’ve got 4.1.1 installed with VW2025 and they’re playing happily together :thumbup:
(Having said that, your icons still don’t work well in VW2025 dark mode…)
Turns creaking anglepoise light to shine onto “your icons still don’t work well in VW2025 dark mode” and drums fingers on tabletop…
Can anyone help me on installing enscape on vector 2025? I tried several times, is it compatible or not?
I have the latest (4.1.1) version of Enscape working fine with VW2025. I have in the past occasionally had to completely uninstall any previous version of Enscape, then reinstall it, and you’ll then find it appears on the VW menu for Tools > Third Party and you can then add the Enscape pallette.
I can see I’m going to have to forgo subtlety and simply come out and say it:- “please can you make your icons visible in VW2025 dark mode”. There, I’ve done it.
Hi @PhilBixby , this should actually already be available - Just in case you haven’t yet, when using Windows 10 you can manually enable this via Tools → Options → VW Preferences → General → Appearance.
If you are using Windows 11 and have already set your main theme to dark mode then It should automatically sync with VW alongside. You may have to restart your machine and/or VW though in order for this to work as expected though.
Hi Demian
VW2025 dark mode works fine - I run Windows 11 in light mode but CAD can be better using dark mode - the problem is just that the Enscape icons virtually vanish in dark mode, whereas the VW native icons have been designed to work in both modes - attached image makes this clear, hopefully…
