I’m trying to render a velocity pass but not matter what frame I’m on when I render out the velocity pass to find out what the max velocity was last frame it always says 0.
Any idea why that would be the case?
I’m on V-Ray for Maya version 2.25.01, revision 22441
Ok. I just created a new scene a just made a single sphere, keyframed it and the “max velocity last frame” worked fine.
So, the new question is, what would cause that not to work in a scene? There are many things moving. Many of them are parented to other things but I don’t feel like that should cause any problems with the max velocity per frame.
So, I was rendering on the farm. But due to this problem we’ve been having where the local computer renders buckets much darker we had unchecked the “use local machine” option.
When I checked that back on, it seemed to work fine. I guess the farm can’t calculate the Max Velocity Last frame.
