Velvet...Vlado?
I have spent 3 days trying to reproduce a realistic velvet material.
I have try everything : very small displacement, glossy reflection, anisotropy etc.. and nothing can realy produce the same effect than real velvet.
I know the falloff map technic in the diffuse slot BUT this is not a physicaly correct way to go.
I have read that Final Render as a special shader for this kind of micro fibers material so I think I am right : this is impossible to reproduce a realistic velvet without the help of a renderer side peace of code.
am I right?
If not I would realy appriceate that Vlado gives us his theorical approch of this material. I mean the way to do it with the existing Vray material, displacement etc…
Can you show some references.
nikki Candelero
Hi n6,
Have you seen this thread?
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=5570&highlight=
Dan
ok. Here is what I m trying to reproduce :
And here is what I can get : as you can see the result is not very realistic for the velvet :
masha are you there??? :lol:
I think you need a specular map with those flowers as well with lots of glossy effect.
nikki Candelero
I hope Masha is flying to Beverly Hills to get her chin done. :o :smile:
You might play with some fall off maps in the reflection and glossiness slots
Try a Perpendicular/Parallel falloff map in Diffuse with the top color set to Blue and bottom set to a whitish color.
did you read my first post? :wink:
Yeah…but most often in this business…if it looks right, it is right!!!
The material you are showing is not velvet. But falloff maps is the way to go here. Nothing we do is “physically accurate”.
I know… but putting a falloff map in the diffuse slot looks like tto me like using a texture to fake reflections.
so why dont u use glossy reflections?with a ward material?
damn… :lol:
I have allready try it! But the result isnt here…
Even with different fallof map fresnel perpendicular/paralele, different IOR index : nothin gives a true and accurate velvet.
And if Final Render has a specific shader for “micro fibers”, well there may be a good reason.
If you think about velvet, it really is a glossy reflective material with many fine fibers. It would be equivalent to very fine hairs wihch is something you would not want to render due to time.
Only other solution I could think of is to play around with anistropy values while having a falloff in glossy reflections.
After looking at your ref picture, I would say that you can achieve the same effect by mixing to materials with different glossy and strenght values..
-Tom
Aren’t airline seats covered with polyester? They’d be pretty expensive to cover with velvet!
Maybe this post may give an idea:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=6041&postdays=0&postorder=asc&highlight=fabric&start=25
Ismael
Nothing to do with the velvet…
But I have to say that this fabric is really ugly (I mean the selection, not the rendering / shader)
That is totally falloff. Look at the pictures…
Look again at Linda’s pillow.
