在3.0版本中,當我在一個場景中創建一個部分並且在場景中的自發光材料,自發光材料將不被顯示。
該顯示器是在2.9版本標準,所以它不是一個模型或重大錯誤。
當我刪除的部分,它會恢復正常。
How to solve this problem?
Hi @Chrid , thanks a lot for your report and welcome to our Forums!
Just to make sure nothing got lost during the translation process, this problem first started to occur only after upgrading to 3.0? No changes have been made to the project otherwise? Can you also send me a screenshot of the material settings of those light sources, please? Finally, can you check if the "Artificial Light Brightness" is not turned down completely in the Atmosphere tab of our Visual Settings?
And finally, can you check if there is no additional geometry in front of the lights whatsoever which could be blocking the source?
Thanks a lot in advance. ![]()
僅出現3.0。相同的模型放入2.9軟件的同事,以及自發光正常。
人造光強度設置,材料亮度設置,相關設置,我已經仔細檢查過,沒有問題。我不是一個新手。
問題在於,我在照明和材料方面做得很好,目前,自發光沒有問題。構圖時,我需要更強烈的空間感。我拉回相機並增加了橫截面。後來我發現,自發光材料是不亮的。
If the automatic exposure option is turned on, the ambient light intensity is too high, which will result in insufficient brightness of the self-illuminating material. Try to reduce the intensity of other light sources.
Please kindly write or translate your posts to English so everyone can directly read what you are saying.
Thank you.
You can try the procedure mentioned above as well from @Yulei , alongside it would also be great to, as mentioned, receive a screenshot of your self-illuminated materials in the Appearance tab. And if the procedure above does not help at all, ultimately it would be great to receive the project itself is that would be possible for further troubleshooting? Thank you in advance for any further replies.
I turned off the auto exposure option. It wasn’t auto exposure or white too white.Now the only solution is PS.Colleagues think that it is possible to read the BIM information of the hidden surface, so the self illumination is covered.(Google translation changed my language, sorry.)
