I’m running the latest version’s of Max and Vray after updating this morning and now I’m experiencing behavior in the VFB that I wasn’t before. If I’m rendering a job and I abort a rendering about a third of the time the image will simply disappear and all I have is a black VFB. However if I check some of the render elements there are images there so what ever is happening is only affecting RGB color. I can’t work like this, please help!!!
Do you have the denoiser or lensfx enabled ? If so - aborting the render right when they are calculating this might happen.
Yavor
Yes I do but I’ve always had them there and it never did this before.
