I’ve been wondering, why as you view render elements in Vray Frame Buffer list and press show alpha channel button, it switches to the global alpha pass instead of showing the current render element own alpha channel, which cloud be different from them beauty alpha pass. Can that be addressed?
Also for Vray Atmosphere render element it will be nice if there is a checkbox to get only the atmospheric element alpha in the pass. Right now it shows only the atmospheric effects in the RGB but still have geo objects in the Alpha. It will be great if the pass can have the atmospherics only both in RGB and A channels or at least have a checkbox for that. Seems that all the compositors are crying for that every time we render fx passes with Vray Volume Grid for example.
Cheers,
Martin
