In the vray help it says that the VFH_RGB_COLOR_SPACE set to 1 should force ACEScg, but to me it looks like its hardcodes everything to sRGB? Or am I missing something?
We can always skip the environment variable and use a render settings node switched to to aces, but it would be better if it also worked with the viewport settings.
Basically it makes the viewport settings useless? Is there anyone not using aces here?
It seems like doc is wrong, you should set it to 2 for aces.
Dear RichardBlank, hello.
Edited in our docs, please excuse us for the misunderstanding.
Try the right value as Andrei pointed out and share is everything working as expected.
TS
