Video Editor Trouble Modifying Keyframes
I’m having trouble doing much with the Enscape timeline. It’s great the first time you create the keyframes and timestamping works well, but when the designers want to add 5 new rooms at various points in the path, I’m finding it impossible to deal with while trying to add keyframes in between existing.
The workaround of stretching the window across 2 monitors only works to an extent.
The workaround of opening the text file is tedious and requires a lot of mental math. (Anyone reading this, don’t modify the .xml file in Excel or it will crash Revit. Ask me how I know.)
Utilities that deals with keyframes better would save me hours/year.
  1. It would be nice to select the last 30 frames for example and batch add 20 seconds to each.
  2. Maybe to supplement the “+” tool between frames, add a tool where you can specify the # frame and it can insert it accordingly.
  3. A zoom in/out similar to most softwares with the little mountain slider would be useful to grab in between frames.
EDIT: Found maybe the easiest way to add frames in between existing.
While in Video Editor, press ESC to exit the current keyframe and see the camera path, then drop an orange camera on the path in between the frames in question. Then you can preview that keyframe and use Update and Timestamp to place it correctly.
See:
RE: vray compatibility is exciting but can we have a decent video editor?
And second to last paragraph of:
Feature Request Process and Roadmap Process
