Thanks for escape, it’s really great.
I have issues when I create Video to do the path I want and the speed.
Is there a tutorial to help ?
For example :
https://youtu.be/nlwN4h6_NP0
Sometimes, it’s going really fast, sometime really slow. I don’t understand how it works.
Thank you very much !
Vianey 8)
Hey @Vianey_Martin , thanks a lot for your post.
In the first instance, you can generally check out our dedicated blog post regarding video creation here.
To adjust the time between keyframes (aka how long it takes from one to the next), you can simply make use of the “Timestamp” function. For example:
You want the duration of keyframe 5 to keyframe 6 to be 10 seconds, go to keyframe 5 and activate timestamp, set the time (in the timestamp) to 40 seconds (which would now also be the overall length of the video up to this frame) go to keyframe 6 and set the time to 50 seconds.
If this is not making it entirely clear yet, and in case the blog post doesn’t help either, you can also gladly schedule a dedicated personal webinar with us here, in which we can gladly show you everything you need to know about the video editor!
