I have been posting this issue for about a year, and I have received no help with it, so I thought I would start a new thread. View image doesn’t work. Picking it does nothing.
Works fine for me. Perhaps the window that pops up is behind something or offscreen entirely?
It works for me as well. Nevertheless, when the image is opened it is centered in between my 2 monitors. Just for a quick check if you use multiple monitors, disconnect one of them and check where the pop-up window with the image preview is going to appear (if it appears at all). This could give us an idea if Pixelcon is right. Also, if you have 2 or more monitors, do they have the same resolution?
Press alt + space then M, then an arrow key to make the window stick to your cursor.
If you are opening a .tx image it may not work.
JPEG seems to work, but no, .TX doesn’t
The view image function utilizes the image viewer built in to max, which cannot read .tx files natively.
Would be better if max would let third parties register file types and loaders. But I guess the API does not work like that.
Oh, nice. I have yet to upgrade. Need to finish existing projects first.
I get that error, but it still doesn’t work for me.
Very odd…
Disconnecting my 4K monitor allows it to be seen on my laptop. Connecting it again causes me to lose it again.
This makes me think it’s maybe just displaying it offscreen for some reason. Try moving it with the arrow keys (I forget the shortcuts to do this all via keyboard since you can’t click it).
As I already stated in post 4
Arrows or alt+space+m do nothing.
First press alt + space, and release, then press M, and release, then press any arrow key, release the arrow key, now just move your mouse cursor until it’s back on your monitor. The windows should be sticking to your mouse cursor. Then click anywhere where you want to window to be located.
It really IS as annoying as this. The times I’ve had to do this I’ve forgotten, as I always forget.
You’d genuinely think there’d be a simpler solution to this after all these years ![]()
Without moving mouse or doing anything else:
hold Alt
press space
release space
release alt
press m and release
press right arrow and release
move mouse if needed.
FG windows should jump to your cursor. Note that the window needs to be the FG window. So bring it to the front with the View Image button first and don’t click anywhere else before the sequence above.
Of course some windows that eat the alt-space don’t work (like PuTTY)
Edit: You could also try right-clicking the Task bar in an empty area and choosing Cascade Windows…
Or Shift Right Click on the window in the Task Bar and choose Move. Then tap the right arrow and release. Then move your mouse.
None of this works. Windows 11 BTW
I was able to get this to work. When you click View Image, you have to be quick while picking alt-space-m-arrow. Basically, you have to try and get it while the View Image is green.
