Viewport rendering is awesome. Is it possible to have the option to have it multiply on top of the SketchUp viewport, so we could have a hidden line view underneath showing through?
Use Ctrl and +/- to control the overlay opacity.
Kind regards,
Peter
And Thea just died a little bit more! Now if you can make it multiply on top so white is ignored, and you got yourself a winner!
That might be possible,
We’ll look into it.
In the meantime, have you noticed that there is an option that can have V-Ray export the view-port to an image:
Extensions > V-Ray > V-Ray Rendering > Export Viewport
It can save out the viewport with the VPR overlay or without it.
Even if you have safe-frames on it’ll still save out a correct result (unlike SketchUp’s export 2d graphic function)
Konstantin
This would be the effect I would like to see. Architects love this feature as they really like to see the linework and the real time render at the same time.
THANKS!!! Guess I should rtfm sometime ![]()
