vignetting on alpha?
why is the vignetting effect on the alpha channel? https://c2n.me/3VHbYbQ.png
used vray next and have not had this in the previous version of vray.
best regrads
themaxxer
You’re correct. I’ll log it in the bug tracker and will post here on any updates.
Thanks for pointing this out.
ok, thanks. also check the wirecolor element, the vignetting is visible there too… maybe it’s also on other elements, I have not checked it.
best regards
themaxxer
You’re right, I’ll update the bug report. Thanks.
