viz 2005 and vray compatability?
anyone know if Vray is compatible with Viz 2005 before i install it?
just got the upgrade in the post…
Yes it is,
as much as 3ds max6 is, VIZ 2005 is based on max 6 SP1.
No problems here, my work is architectural stills.
Fermí
thanks fermi.
i’ll pop it in now then!
:smile:
just got viz2006 upgrade - do you know if the max7 plugin works? :slight_smile:
Thanks.
Yes, it should work. I read somewhere that Viz2006 is based on the 3dsmax7 core, so the max6/max7 version of VRay should work with it.
thanks Vlado. i’ll give it a try and report back.
