vray and VIZ 2005
which vray version is compatible with autodesk viz 2005?
i noticed that number version of viz executive is 6.0… 8)
thanks
This was asked in an earlier thread but I think you can use the max6 version of V-Ray for Viz 2005. Search the forum for more info.
-dave
dave is right,
1.09.03r for 3ds max6 working on VIZ 2005 same as it does on 3ds max6 here!
Cheers
Fermí
I have a question related to the VIZ 2005. In my work, most of the 3D modelling occurs in ADT (Architectural Desktop 2004, buildings and stuff), which comes together with Autodesk VIZ Render, which, according to the Autodesk, is a simplified version of 3D Studio VIZ, containing only the VIZ render engine.
Is there any way, to have Vray installed with VIZ Render and have it fully operational as it is with 3DS VIZ and MAX. Has any of you had a try with this, yet?..Does it work with VIZ Render?..
I do not really need such a complicated software as 3DS VIZ and MAX installed on my PC, after all, since I use only its rendering capabilities.
Fermi is right. I’m running Viz 2005 with Vray (Max6) and its running just fine. Check out this thread http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?p=48526&highlight=#48526 :smile:
It will not work with viz render in ADT
