I`ve done this:
- enabled the built in frame buffer;
- have checked output channels: real RGB, reflection;
- have selected expotential color map (1,1);
- unchecked clamping there;
= all my G-buffers are black except for standard RGB.
What have I done wrong?
I know that this feature usually works, when I start a new MAX scene from scratch and do some test it`s working perfectly.
Only when the real job comes it lets me down :(.
I`ve just checked it :
I have reset all, created a completely new file, added two simple boxes, then applied a simple VRmaterial with reflection to it, and - everything was fine - I could see the reflections channel as well as RealRGB !
So I`ve saved these rendering settings (using Vray preset manager) and applied these settings to my job file - it was the same again !
Everything black in G-Buffer layers !
PS second thing : in this scene I always get the message: “scene boundary is to big, possible raycasting errors”. What the heck is this? Is there a limit of how huge your site should be? I`m doing urban-scale analysis +architecture, so my file`s over 250m x 250m !!! (I`m working in centimeters)
