Does it crash immediately when you open the scene? In that case, try using OpenGL viewport driver and see if it helps. If yes, then it is an issue that is corrected for the service pack.
Hey I have this exact same issue with only one particular scene ! So every time I work on it I need to switch back to opengl mode.
Didn’t think a second that it could be related to vray though. Hopefully the SP1 will soon be here to correct that.
